Old 09-23-2015, 03:31 PM   #1
thunderlights
Help! boomerang, sidemarkers, tail lights not working!
My side passenger sidesmarker broke off during a drive, and one of wires for the connector popped out. I tried to fix it, but only made things worse. for starters i ended up taking the whole connector off, and i accepted the fact i wouldn't have 1 side marker light. well its more than that now.
When i put the bumper back on i noticed the other sidemarker doesn't work, as well as the fog lights, the led boomerangs (2014 brz sportech) and just recently noticed the rear tail lights don't work either. What does work however is the LED DRL strip, the headlights, the brake lights and all signal lights work.
At this point I'm assuming all the lights that don't work are part of one circuit and by trying to fix the sidemarker i have shorted something and blew a fuse? Electrical work is by far my weakest skill (if it isn't obvious already) and i could really use some help or suggestions. Any input will be greatly appreciated. Thank you!
thunderlights is offline   Reply With Quote
Old 09-23-2015, 03:43 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Go check the fuses, it's likely to be the issue. If it's not then let us know. Always check the fuses 1st, it's easy and usually the cause of electrical failure
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-23-2015, 04:32 PM   #3
thunderlights
Which fuse would i check? Also how do i know that fuse is blown?
Sent from my SM-G850W using Tapatalk
Old 09-23-2015, 04:42 PM   #4
swarb
Check the fuse with the problem you have.
Google blown fuse.
Old 09-23-2015, 10:46 PM   #5
thunderlights
Yeah so it turns out the tail light fuse also controls the boomerangs side markers and fog lights as well. This really wasn't made clear anywhere. I got it all working again by replacing that one fuse. So if anyone ever runs into this issue in the future this will be here. The tail light fuse is the #4 fuse in the fusebox located by the pedals. Cheers!!!
The Following 2 Users Say Thank You to thunderlights For This Useful Post:
g0odspeed (02-17-2019), GrantedTaken (08-10-2018)
Old 01-08-2020, 01:27 AM   #6
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
You definitely saved my ass! I took my car to a shop to get body work done after an accident, and they messed with my wiring and my tail lights stopped working. Thanks to you and coming across this thread, I changed the fuse and my lights instantly work now!
Thank you!
Twitchy313 is offline   Reply With Quote
Valenti Tail Lights - Running Lights not working at all Antstronaut Cosmetic Modification (Interior/Exterior/Lighting) 12 08-10-2017 07:11 AM
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 01:19 PM
BLUEBATMOBILE vinyl tail lights overlays, roof wrap, and sidemarkers smoke virjose Exterior Parts (Aero, Lighting, Etc.) 17 05-09-2014 04:59 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) -- General Topics 18 04-27-2014 02:09 AM
TOM's USDM Spec DOT Red Tail Lights -- with OEM style Sidemarkers & 86 Piston Plate 86_ZN6 Exterior Parts - Lighting 8 09-05-2013 01:21 AM
