Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-22-2014, 01:16 AM | #15 |
Drives: Scion FR-S 2013 Raven
Whiteline crossmember bushing insert review
Does anyone hear an little cluck sound from the rear during you hit the gas after the installation of these bushings?
I don't think it's a problem because the rear is locked now and very more stiff. I love and appreciate the feeling again after one weeks.
o= FR-S =o |
03-22-2014, 11:43 AM | #16 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Sent from my LT30at using Tapatalk |
03-22-2014, 12:06 PM | #17 |
.75" on RCE yellows
03-22-2014, 04:50 PM | #18 |
I have Mach V springs and Whiteline link on the rear.
Then you suggest this is normal? This is what I think too... It's a clunk like when you engage the trany from the neutral to the first gear...The "normal" clunk they say... But in this case the sound come from the rear when you accelerate hardly. Maybe the bushings just increase a little bit a sound we have at the beginning?
o= FR-S =o |
03-22-2014, 07:12 PM | #19 |
I've got no added noise after installing the bushings.
03-22-2014, 07:19 PM | #20 |
Even if you tap the gas pedal? I mean this happen only when you hit the gas... I don't speak about NVH during driving.
o= FR-S =o Last edited by Mikepage; 03-23-2014 at 09:44 AM. |
03-27-2014, 08:19 AM | #21 |
The "bung sound" when you compress and you re-accelerate seem to be less or not present anymore with the positive shift bushing.
Then this is only because the rear was more tight you can hear this sound.
o= FR-S =o |
03-27-2014, 08:45 AM | #22 |
i'm sorry, what?
Drives: Canada
glad you took our suggestions and went the bushing way before the other stuff.
03-27-2014, 08:56 AM | #23 | |
Yes I have updated my other post. http://www.ft86club.com/forums/showthread.php?t=58553
o= FR-S =o |
03-27-2014, 09:01 AM | #24 |
Drives: Vortech Supercharged FR-S
Are these black inserts newer version and better than the yellow one?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
03-27-2014, 09:06 AM | #25 | |
See the link below : http://www.ft86club.com/forums/showthread.php?t=59424 http://whitelineus.com/fadetoblack/
o= FR-S =o |
The Following User Says Thank You to Mikepage For This Useful Post: | Figo (03-27-2014) |
08-22-2014, 12:23 AM | #26 |
Whiteline = awesome!
o= FR-S =o Last edited by Mikepage; 10-22-2014 at 09:29 AM. |
11-09-2016, 03:02 PM | #27 |
Drives: Hyper Blue BRZ
is this kit alone good enough for daily driving (without adding the diff kdt925) bushings ?
reason i ask is because there are many reports on roughness of kdt925 |
11-09-2016, 03:30 PM | #28 |
Off Topic
For daily driving you don't need any of them. Either would be fine for removing compliance from the system; both together would be better. There's nothing that says this one is better than that one, they must be done in a certain order, etc... But any modification will always have trade-offs; it's just a question of what trade-offs you're willing to accept in exchange for the positives presented by the modification. The movement that we call slop and want to remove was specifically put where it is in order to minimize NVH inside the cabin. Most of the movement comes from the diff carrier bushings; specifically the two large bushings in the back. KDT925 minimizes that movement at the cost of slight gear whine at low speeds in low gears. Aside from those bushings, the entire subframe flexes on its bushings under load; whether it be cornering, acceleration, or deceleration. KDT922 minimizes that movement, against at the cost of slightly increased NVH. Which movement do you want to minimize and at what cost?
I went with the KDT925 over the KDT922 because I felt that the two rear diff bushings were the biggest culprit. The trade-off is there is a very slight gear whine in low gear at low speeds, especially when coasting. My radio is loud enough that I don't hear it, so it's worth it to me. Neither is especially difficult or expensive, so start with either one, and if that doesn't meet your needs, do the other one. |
The Following User Says Thank You to gramicci101 For This Useful Post: | smg1138 (05-09-2017) |
Similar Threads | ||||
DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 02:23 AM |
Whiteline Rear Crossmember-Mount Insert Bushing: Great pricing | b2autodesigns | Brakes, Suspension, Chassis | 1 | 02-18-2013 11:41 AM |
Installed the Whiteline crossmember bushing(no pics sorry) | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-26-2013 02:00 PM |
Whiteline transmission bushing and Perrin shifter bushing review. | Superhatch | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-09-2012 08:40 PM |
