Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-23-2016, 04:45 PM | #15 |
driving smoother faster
Drives: Sold
After exchanging quite a few thoughts with @CSG Mike on my needs and opportunities for improvements, some SPL and Cusco bits will be added. Swaybars will remain stock, there will be less rubber in the suspension, and it should all play nicely with new JRZ doubles.
05-24-2016, 08:12 AM | #17 |
Drives: Sold
Here is what's getting added soon, courtesy of CSG via SPL and Cusco:
SPL Adjustable Rear Toe Arm SPL Bumpsteer Adjustable Front Tie Rod Ends SPL TITANIUM - Rear Traction Arm 956 464 AV - Front lower control arm front spherical bearing 692 464 BV - Front lower control arm rear bushing 965 464 LV - Rear upper control arm front bushing 965 464 IV - Rear upper control arm rear bushing 965 928 A - Differential mount collar 965 927 A - Rear subframe collars Looking forward to trying these out with JRZ DA on 500lb/600lb (9k/11k) springs and Toyo RRs...with a little luck, may be ready for 3 days at NJMP with NASANE 6/17-19. |
The Following User Says Thank You to dp1 For This Useful Post: | CSG Mike (05-24-2016) |
05-24-2016, 08:59 AM | #18 |
If you winter drive your FRS be prepared for a workout getting the OEM toe arms off.
The Following User Says Thank You to jvincent For This Useful Post: | dp1 (05-24-2016) |
05-24-2016, 04:38 PM | #20 |
Just the tip
I was very surprised how nice the car is for daily driving even with all the mounts and bushings. Our cars are great at having the frame take it all and not have stuff vibrating all over the place like some cars. I would recommend doing all the stuff I've done even for non-track canyon carving enthusiasts. I barely feel any vibrations. I do feel what the car is doing much more and things are more responsive and solid feeling.
I have my eye on the "Whiteline KCA 435 front roll center bump steer correction kit" but haven't bought it yet as I'm undecided if I need it. Here's a list of what I have so you don't need to visit my build thread, even though you should. Whiteline KCA416 Front Camber adjusting bolt 16mm Whiteline Rear Control arm - upper inner bushing (camber correction) KCA326 Whiteline Front Control arm - lower inner front Anti-Dive / Caster Correction Kit KCA434 Whiteline Front Control arm - lower inner rear bushing W0509 WhiteLine Rear Crossmember Mount Bushings KDT922 Positive Traction Kit Whiteline Front Sway Bar with bushings Front 20mm Fixed BSF45 Whiteline Rear Sway Bar with bushings 16mm Adjustable BSR53Z Whiteline Front Steering - rack & pinion mount bushing KSR210 Whiteline Rear Trailing arm - lower front bushing W63414 Perrin Poly Rear End Links Front strut tower bar Perrin front control arm brace Subaru Impreza OEM Conical Washers (Subaru P.N # 20326AA000) RCE TARMAC 2 COILOVERS Whiteline Gearbox Positive Shift Kit KDT926 Perrin Rear Shifter Bushing Whiteline KDT925 Rear Diff - mount in cradle & support outrigger insert bushing MTEC Shift Spring Kit Chase Bays stainless steel clutch line Autozone slave cylinder (smaller than stock)
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
05-24-2016, 05:43 PM | #21 |
Drives: '23 BRZ Limited
Your roads must be nice up there (actually a friend from OR here this weekend commented how terrible our roads are).
I'm Ground Controls, solid mounts front and rear and 255/35 Star Specs. The ride is atrocious and loud. And I'm about to put SPL LCAs on the car to get some travel back and be able to adjust the camber. |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | dp1 (05-24-2016) |
05-24-2016, 11:10 PM | #22 | |
Just the tip
05-25-2016, 02:25 AM | #23 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | dp1 (05-25-2016) |
05-25-2016, 08:43 AM | #24 |
You seriously have to see the quality of our roads. It's atrocious.
I'm visiting Portland in about 8 weeks to see if I want to get out of this corrupt, underfunded conservative hell hole! |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | CSG Mike (05-25-2016) |
07-07-2016, 09:12 PM | #25 |
Drives: Sold
Love the suspension upgrades on track, very tight and precise between JRZs and metal-on-metal joints instead of rubber bushings but not snappy
The Following User Says Thank You to dp1 For This Useful Post: | MaximeT (07-08-2016) |
07-08-2016, 07:45 AM | #26 |
Drives: 2013 FRS / 2013 427 Vert
It would be helpful if these individual pieces were bundled into packages where each component compliments the other and represents the most logical progression order.
I hate to use an over used term but in effect Stage I Stage II etc.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
The Following User Says Thank You to Deep Six For This Useful Post: | dp1 (07-08-2016) |
07-08-2016, 08:28 AM | #27 | |
Drives: Sold
Would be very happy to get votes on options that belong to Stage 1/2/3 and compile into the top post. |
07-08-2016, 08:47 AM | #28 | |
Drives: '15 BRZ RA
It is happening also on our cars. Reason is not the high G corners, but the height difference in the car. When you change the suspension, you usually decrease also the wheel fender gap. Factory end links were designed for the OEM height and if you keep the same links, then the stress on them is much bigger. It is just likely to happen failing in high G corners. Too bad that most of the aftermarket coilover brands (even big names) don't provide updated end links. They just take your money and leave you alone to think about all these details. |
The Following User Says Thank You to nikitopo For This Useful Post: | dp1 (07-08-2016) |
Similar Threads | ||||
Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? | themajesticone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 80 | 11-14-2014 06:01 AM |
Coilover spring diameter vs OEM | ahaghshenas | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 11-25-2013 12:26 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
Kronos Coilover/Spring MEGA THREAD! Special Prices inside! | KronosPerformance | Brakes, Suspension, Chassis | 46 | 09-09-2012 08:22 PM |
