Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
06-04-2018, 08:53 AM | #29 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Here's a comparison of mine. Took these photos at the fastest shutter speed to get the darkest image possible. The DRLs are definitely the brighter set during the day on my car.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
06-04-2018, 05:27 PM | #30 | |
Drives: toyota 86 2017
Also what angle and how far away were you when you took these pics. Do you have the LED headlights or other types of headlights (incandescent, etc) |
06-04-2018, 05:32 PM | #31 | |
A.K.A. Starlord
Also that's only two photos above. The top image is just narrower since it doesn't include the DRLs, which were off. I was about... maybe 20-25 feet away from the car, and the phone was about 4 feet off the ground. They are the factory HID headlights from before the facelift.
06-04-2018, 05:45 PM | #32 | |
Ok...with the car light stalk on auto and able to shut off automatically. On my 86 List of Lights that are on In daytime, with sensor uncovered. DRL LED strip In daytime, with sensor covered. (Like light mode) Headlight DRL LED strip Rear L-Shapped parking light Left and Right fender parking lights Is it the same on your brz? |
06-04-2018, 05:51 PM | #33 | |
A.K.A. Starlord
"Night Mode": Headlights, boomerangs, front side marker lights, rear side marker lights, tail lights, all interior dash lights.
06-04-2018, 05:57 PM | #34 | ||
Do you notice any cutoff from 2 feet up or is it gradual? |
06-04-2018, 06:00 PM | #35 | |
Someone had also mentioned that my radio display would be unreadable, I have noticed no change in brightness. Maybe on the toyota version, the difference between night/day is minimal on the display? On your BRZ, if you cover up the sensor, do you noticed a difference in brightness of the radio? No need to mess with the scroll wheel. I don't see much difference in brightness. Then again I wasn't paying much attention but would think I would have noticed. Last edited by pcguru2000; 06-04-2018 at 06:14 PM. |
06-04-2018, 06:19 PM | #36 |
Drives: UK GT86
@pcguru2000 you're making this so much harder than necessary. If you have a button pushed 86 I would assume that it's the same as my UK pre-facelift GT86. That would essentially have 3 modes:
0 or Auto in daylight: Front DRLs after handbrake has been dropped for the 1st time. Sidelight: Front DRLs and rear lights Main beam or Auto when "Dark": Front DRLs dimmed, headlights on and rear lights on. They should also all turn off when you take the key out. Therefore why is leaving the stalk on main beams any different to putting tape over the sensor? The BRZ is different as the DRLs are low down in the bumper and they have the Boomerang in the main lights. These operate in different conditions and not like the GT86.
.: Stealth 86 :.
06-04-2018, 06:24 PM | #37 | |||||
A.K.A. Starlord
Aperture: F2.4 Shutter Speed: 1/24000 ISO: 200 Quote:
06-04-2018, 07:23 PM | #38 |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
If ever there was a thread about reinventing the wheel, this is it.
-Manufacturer keeps feature that allows OP to do what he's intending. -OP doesn't like that, decides to instead bypass and/or modify other features to achieve the same effect. -Meanwhile, simplest solution is sitting unused, supplied by the manufacturer. So yeah, want your headlights on when you drive? Turn the selector as needed. This falls in the same category as "I want my fogs on 100% of the time because vision" threads. Let the DRLs do their work, let the sensor do it's work, and if you come across a situation of heavy rain or thick fog, then turn on your headlights as needed. Also, as someone else mentioned I believe, many new cars use that sensor in conjunction with climate control as well. Not 100% sure if ours do but it wouldn't surprise me in the least. If it gets inaccurate info, it would either have trouble adjusting the set climate controls, or throw a code and enter into a "default" control mode. Another reason to let it do it's work. Last edited by sharpsicle; 06-04-2018 at 07:35 PM. |
The Following 3 Users Say Thank You to sharpsicle For This Useful Post: |
06-11-2018, 03:07 PM | #39 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
pcguru2000 still fighting against the world..
who will win? |
06-15-2018, 08:57 AM | #41 |
Similar Threads | ||||
OFT tune still get O2 sensor light | DarkestBuddha | Software Tuning | 10 | 12-04-2014 04:14 PM |
Check engine light... Map sensor | cjsporl1996 | Issues | Warranty | Recalls / TSB | 4 | 03-29-2014 05:37 AM |
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
electrical issue? unichip and left led fog light not playing nice | tracerit | Software Tuning | 2 | 10-07-2013 09:09 AM |
