Old 02-26-2020, 04:27 PM   #71
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
As the season starts to warm up; we are starting to see these sell again. We only have a handful left on the shelf so if you definitely want one before spring; send us an e-mail or purchase a unit from our website!
If you have any questions, don't hesitate to ask!
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Clutch Dog (02-26-2020)
Old 06-22-2020, 02:37 PM   #72
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any new user reviews for this radiator?
Old 01-22-2021, 12:24 PM   #73
RippinRich
Drives: 2017 BRZ Premium
Not finding any reviews for this. Is the extra cost worth it over a CSF or Mishimoto?
Thanks!
RippinRich is offline   Reply With Quote
Old 01-23-2021, 01:58 PM   #74
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I've had one of the first samples of this on my car for about 4 years and its been great. Previously I had a CBR radiator and needed to use a lower temp thermostat to keep temps in check during track sessions. Eventually I had a leak in that one and upgraded to the Verus. After the upgrade I had to swap back to a factory thermostat due to low coolant temps. Factory ecu will give a CEL if coolant temps don't come up quickly enough.
Thanks!
Depends on your use case. For a street car upgrading to this probably doesn't make much sense. But for a car that sees track time and high temperatures its worth it. IMO this isn't a comparable product to the two you mentioned and the pricing reflects that. The Verus unit is made from high end motorsports grade components, like the Denso high density core, while the others are not. If you want a no compromises high end radiator this is the one.
It's done a great job on my turbo setup and will soon find out how it if it has enough cooling capacity for a built LS3. I don't expect it will have any problem keeping up.
kask2_6.0 is offline   Reply With Quote
The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post:
Espi (05-24-2022), Lonewolf (01-23-2021), VerusEric (01-28-2021)
Old 01-23-2021, 05:19 PM   #75
Chuckls
Moutain Runner
Thanks!
CSF and Verus are the only two replacement radiators I'd ever recommend. Shitimoto should not be considered. Their fan shroud is known to cause overheating. Stick with stock unless you NEED an upgraded rad.
I went with Verus because they're the best, and Clay gives the best handshakes. Eric also sends muscle pix. Their customer service is top notch.
Chuckls is offline   Reply With Quote
The Following 3 Users Say Thank You to Chuckls For This Useful Post:
Joveen (02-19-2021), Teseo (05-24-2022), VerusEric (01-28-2021)
Old 01-28-2021, 08:20 AM   #76
VerusEric
VerusEric's Avatar
Thanks!
Like the guys above said, the two units aren't really comparable in my opinion either. The radiator we designed and build is a no-compromise, the best of the best in a factory-fit radiator, unit. We have had multiple guys have overheating issues with turbochargers or superchargers or V8 swaps, come to our radiator, and ours work well for their setup.
I hope that helps some.
Jdmjunkie (05-26-2022)
Old 05-22-2022, 04:39 PM   #77
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump for the hotter weather...
Old 05-23-2022, 11:17 AM   #78
Chuckls
Moutain Runner
You got a verus rad yet?
Old 05-24-2022, 12:27 PM   #79
RedReplicant
Drives: None
Mine has one, kept coolant temp in check with a Harrop setup and 100f+ ambient on track. Load should be a bit lighter now, but it is a nice piece.
RedReplicant is offline   Reply With Quote
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
Espi (05-24-2022), Jdmjunkie (05-26-2022), Lonewolf (05-26-2022)
Old 05-24-2022, 01:57 PM   #80
Jdmjunkie
Drives: Scion FR-S 10 Series
Would this benefit me as someone who lives in the Vegas valley? I am currently on a stock engine soone to be K-swapped, I also have a oil to water cooler. In the heat of the day any acceleration will increase coolant temperatures. Daily and track driven.
Or would something like a Koyorad be more in line with my needs?
Jdmjunkie is offline   Reply With Quote
Old 05-24-2022, 10:14 PM   #81
Chuckls
Moutain Runner
always support verus <3
The Following 2 Users Say Thank You to Chuckls For This Useful Post:
Jdmjunkie (05-26-2022), RedReplicant (05-24-2022)
Old 05-25-2022, 12:59 PM   #82
Jdmjunkie
Oh I agree, and have supported them by buying other products.
I just want a radiator that fits my needs, I do not want to over cool the engine.
Old 05-30-2022, 04:54 PM   #83
VerusEric
VerusEric's Avatar
That is an impossible question to answer, honestly. The Koyorad may be enough, or one of our radiators may be necessary. It's really difficult to say.
I will say our radiator uses the same cores that are used in F1, IndyCar, Rally, etc. The core we specify is the best of the best, made right here in Indianapolis by PWR/C&R.
Old 05-31-2022, 09:56 AM   #84
grumpysnapper
grumpysnapper's Avatar
I really know it shouldn't irk me, but why coat your (excellent) product in a layer of parochial over reach?
There is absolutely no shame in saying its based on, or is, an imported PWR radiator /core made by PWR, at PWR.
Part of the pleasure in something like a PWR product is that it is actually truly made in the same factory as an F1 radiator.
PWR still says it makes all its radiators/cores, including the F1, WRC, Indy etc etc stuff, at its HQ.
I've been with Kees Weel a few times in his HQ, even been allowed to handle 2 or 3 of the F1 teams different radiators .... and some of the even more amazing/hard to even fathom military cooling modules.
Hearing him explain a couple of years ago how (at the time) F1 teams wanted to achieve an additional weight saving of less than 100grams per radiator, and in doing so were willing to go from using 2 x $80000 radiators per car over two race weekends (then shipped back to be fully rebuilt) to 2 x $120000 radiators per car per single race weekend...was a sobering lesson in engineering extremes.
grumpysnapper is offline   Reply With Quote
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Gauging Interest: High-Quality Vinyl (Reflective) Plate Replicas Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 03:06 PM
Gauging Interest for a Tint Install Day @ Pure Automotive Performance Pure Automotive Mid-Atlantic 71 03-03-2013 10:22 PM
Gauging interest: GB on a super high quality drying towel Hamza7 CANADA 34 11-25-2012 05:25 PM
