Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Cosmetic Modification (Interior/Exterior/Lighting)
Old 11-13-2019, 01:35 PM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Wiring Diagram for BRZ OEM 12-16 DRL?
Hi guys, the BRZs in our country dont come with DRLs. I was able to source a pair including foglight bezels to replace my non-drl ones.
Question is, how do I go about installing the DRLs in the same way OEM has it installed? Is ther any instruction diagram and additional wiring i’ll need?
I want it to work and installl how exactly oem is. (Always on upon start, turns off when Headlights are on or if ebrake is enganged)
Is there existing wiring already?
Do I just need to put in the relay? where is the DRL relay if ever anyway? (cant seem to see it in the fusebox!)
Will I get the same functionality?
leevanf is offline   Reply With Quote
Old 11-13-2019, 05:17 PM   #2
fun police
first gen wiring diagram/manual is online. see my sig.
Old 11-13-2019, 11:00 PM   #3
leevanf
leevanf's Avatar
Hi Ultra, i noticed the BRZ manual/wiring doesnt have anything on the DRLs. Perhaps since its an optional part around the world.
Given this, would you happen to know if there is an existing relay or what for units without it from factory?
Old 11-14-2019, 02:30 AM   #4
fun police
Hi, leevanf. Based on others' experience, I've learned that the harness is common out to the peripheral devices. The heated mirrors are an example. The cable from the mirror to the connector in the dash and a relay are all that the heated mirrors need to complete the package.
There is a DRL relay shown in the wiring diagram. You'll need at least that and the load resistor but... I remembered as I was driving home tonight that the FRS cuts back the power on the high beam halogen lamps for DRL. Doesn't the BRZ have some special LED thingy for the DRL? Does it need a resistor? Hmmm...
Old 11-16-2019, 12:57 PM   #5
soundman98
Boost is Whack. N/A4LYFE
soundman98's Avatar
Drives: '14 brz limited
shouldn't need a resistor on the brz drl's. and they're 13v minimum, so they don't light up unless the car is running. really just need the relay to turn them off when the headlights are on to comply with certain state regulations that have limitations on the number of white light sources turned on at any given time.
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
Old 11-18-2019, 12:23 AM   #6
leevanf
leevanf's Avatar
Would you happen to know if a non factory car DRL has both wiring and relay for this?
If not, what does the relay look like in the fusebox?
Old 11-19-2019, 10:44 PM   #7
soundman98
soundman98's Avatar
i don't know the answer to either of those questions.
hidplanet build log
BRZ Headlight pin/wiring diagram 2SeeKU Electronics | Audio | NAV | Infotainment 10 01-21-2020 08:35 PM
2017 wiring diagram solidsnake11 DIY (Do-It-Yourself) Guides 5 12-28-2019 12:33 AM
O2 sensor wiring diagram g0odspeed Electronics | Audio | NAV | Infotainment 1 12-18-2015 06:01 PM
Wiring diagram for BCU 1GiantTurtle Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2014 11:10 PM
2 SVC+ 2 DVC WIRING DIAGRAM PineappleFriedRice Electronics | Audio | NAV | Infotainment 8 03-03-2014 01:12 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
