Old 09-24-2018, 03:22 PM   #15
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
I opted for a drop in since I'll be swapping the motor next year and didn't want to waste a few hundred for a full intake knowing that ahead of time.
I went with the K&N for about $40 and it made a noticeable improvement on the butt dyno and picked up about .5 mpg as well over the stock filter.
Axis2011KR is offline   Reply With Quote
Old 09-24-2018, 04:34 PM   #16
radroach
Drives: car
@Aluma007 For a high flowing dry filter, I think you'd only want to run for track use only or for short term in only clean-driving environments. Oil analysis shows that silicon content is directly connected to how well your air filter works. No these aren't washable or reusable.
The Following User Says Thank You to radroach For This Useful Post:
Aluma007 (09-24-2018)
Old 09-24-2018, 08:12 PM   #17
86MLR
86MLR's Avatar
The 17+ are dry paper elements.
Old 09-25-2018, 04:50 AM   #18
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Overall most aftermarket air intake systems mostly did nothing-worsen HP. Some even brought up CELs.
Drop In Filters were all comparable 2~5 hp (practically noise from various runs, heat soaking, etc.).
Some dry drop in filters are washable. ie. https://afepower.com/media/pdp-files/31-10094-1-is.pdf
Oils are washable as well. And no, its not once week or month. The environment you use it in and the number of miles you drive plays a large factor on how often you wash it. aFe oil says to wash your oiled filter every 30,000-50,000 miles. If you drive less than that, then aFe suggests you inspect the filter once a year for sufficient oil (blue color is the oil).
Why did I mention aFe? Because that's what I'm using and too lazy to look up other brand suggestions.
Old 09-25-2018, 07:48 AM   #19
chipmunk
Drives: _
I read on Yamaha forums that the intake filters can be oiled using 2-stroke engine oil (based on the assumption that 2-stroke oil can be safely mixed with gasoline for combustion). Can anyone confirm this?
I used 2-stroke oil on my bike with no issues, but my R6 doesn't have any O2 sensors.
chipmunk is offline   Reply With Quote
Old 09-25-2018, 07:51 AM   #20
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
But why? Oiled filter manufacturers provides cleaning kit with fresh oil. And its not expensive.
Old 09-25-2018, 08:12 AM   #21
chipmunk
Drives: _
After hearing about K&N-MAF issues, it felt like a safe option.
In hindsight, I'll be switching back to dry OEM style filter for both soon. Trying to eek out 2 or 3 hp from the engine that makes no difference in real life.... is not worth it for me. Heck, if I really wanted every single one of those few extra HPs, I should have bought a used MR2, RX8, Elise... or even a Camaro 2.0T!
Old 09-25-2018, 08:53 AM   #22
Axis2011KR
I'm not saying when you clean it and re-oil it that you couldn't go overboard and cause issues but with a brand new filter I've never heard of it happening and have not experienced anything like this personally.
I've run them on cars from 140whp-550whp. I run one on my FR-S (drop in), ran them on both of my Evo X's full intake style with bolt ons and E85, and run one on my modded F-250 Diesel also full intake style. I've probably put close to 350k miles on aftermarket oiled filters between all my vehicles that have run them and never had a single issue.
You've got a far better chance of damaging your MAF by banging it around during an install of an aftermarket intake then by having blow by oil from the filter.
Old 09-25-2018, 11:12 AM   #23
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
The surface area on these are so much better than before
Breadman is offline   Reply With Quote
Old 09-25-2018, 01:49 PM   #24
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
that only really happens to people that over oil their filters.
There also appears to be some misunderstanding as to how frequently you need to clean and re-oil the filter. I've seen people post how they have to do it weekly. The time right after re-oiling poses the greatest risk of oil splattering on the MAF sensors. These situations are probably where you're hearing the horror stories - people Incorrectly using the products.
Honestly you save a good deal of money using washable filters like your K&N. If you're Really paranoid you can use washable dry filters.
Old 09-25-2018, 03:35 PM   #25
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Just grabbed the K&N drop in filter too. I'm in it for the butt dyno improvements.
kevaughan is offline   Reply With Quote
Old 09-25-2018, 04:31 PM   #26
JIM THEO
Drives: BRZ 2018
I use K&N drop in filters since 2000 on Impreza GT, WRX, STI, EVO6, Suzukis and now on BRZ.
Most important is the oiling procedure and the first few kms after oiling, I used to oil the filter slightly, let it in absorbing paper for 1-2 days and finally blow with air gun for any remaining extra oil.
Then I fit it and drive smoothly the first few mins just to be sure it wouldn't hurt my MAF.
So far no problem in any of my previous cars!
JIM THEO is offline   Reply With Quote
Old 09-25-2018, 04:47 PM   #27
kevaughan
kevaughan's Avatar
Drop in filters.
-snip-
Old 09-25-2018, 07:26 PM   #28
Aluma007
Drives: 2017 Brz
the 17+ AT use the previous years rounded corner elements...I'd probably of kept the OEM one if it had the new versions.
Aluma007 is offline   Reply With Quote
K&N drop in air filters..............will you? Liquidsnake Engine, Exhaust, Transmission 94 10-23-2014 09:04 PM
Drop-In Air filters lavisxice Engine, Exhaust, Transmission 26 03-21-2013 09:04 PM
Oil Less drop in air filters Skurj Engine, Exhaust, Transmission 3 02-25-2013 06:26 PM
Drop in Filters?!?!? PrDarkKnight Engine, Exhaust, Transmission 4 12-04-2012 10:58 AM
Drop in filters phenom86 Engine, Exhaust, Transmission 8 10-07-2012 04:50 PM
