09-10-2018, 09:51 AM | #3473 |
Drives: 2018 BRZ tS
09-10-2018, 10:35 AM | #3474 |
Drives: 2014 Subaru BRZ
Correct, the modifications over the stock/base car would all count the same as if they were non-OEM parts installed by you, so you'd have to remove stuff like the wing and different springs would automatically put you in STX.
The Following User Says Thank You to 14stu For This Useful Post: | Scala (09-10-2018) |
09-10-2018, 10:45 AM | #3475 |
Drives: 2018 BRZ tS
Thank you. I guess I'll have to see how competitive it can be in STX and how much it'll cost to get it there.
09-10-2018, 02:46 PM | #3476 |
Drives: 2013 FRS
Any news on it yet? I'm curious how it's working out/possibly interested in one once they're available. My driving style likes front roll stiffness.
09-10-2018, 04:57 PM | #3477 |
Drives: 18 BRZ tS
09-10-2018, 05:06 PM | #3478 | |
Drives: 2022 BRZ
Day 2, the car was loose and I should have made a change after my 1st run.....instead I stiffened one side of the bar after my 2nd run and it was really good for my 3rd run( I coned away 4th place) I was able to make the bar adjustments between runs even with being a 2 driver car. Simmons
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
The Following 2 Users Say Thank You to Simmons For This Useful Post: | DocWalt (09-11-2018), strat61caster (09-10-2018) |
09-10-2018, 05:08 PM | #3479 |
The Following User Says Thank You to 14stu For This Useful Post: | strat61caster (09-10-2018) |
09-10-2018, 05:18 PM | #3480 |
Drives: 18 BRZ tS
Just read September Fastrack... tS is in C-Street at least
https://www.scca.com/pages/fastrack-news |
The Following User Says Thank You to 86prime For This Useful Post: | strat61caster (09-10-2018) |
09-10-2018, 05:43 PM | #3481 |
Drives: 18 BRZ tS
09-10-2018, 11:05 PM | #3482 |
Drives: BRZ 2017 Pure Red, MT
09-11-2018, 05:15 PM | #3483 |
Drives: 2022 BRZ
4 holes....plus you can just do 1 hole instead of both sides.
Simmons
2022 BRZ 71 STR
The Following User Says Thank You to Simmons For This Useful Post: | nico_rsx (09-11-2018) |
09-12-2018, 08:06 AM | #3484 |
Drives: 2016 Scion FRS
Brian also pieced together a rear bar (ND arms maybe?) and said we can expect a production version at some point.
Beautiful pieces and if you've ever dealt with one of these style bars along with a stock designed bar that might tend to bind, it is a must have... |
The Following User Says Thank You to steverife For This Useful Post: | Simmons (09-12-2018) |
09-15-2018, 06:34 PM | #3485 |
Drives: 15 BRZ
What's everyone at for ride height? Or is it really even worth taking it into consideration for these cars?
Delta/CENLA Region SCCA - DS
09-15-2018, 06:42 PM | #3486 | |
Drives: 2013 Raven FR-S
I think it matters to some extent, but you don't have to be super low for STX. During Autocross season I set my ride height to 13" from hub center to fender. That's somewhere in the neighborhood of 1.5" to 1.75" lower than stock. |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
