03-27-2018, 08:51 AM | #379 |
Wes
This thread should be called the FI fearmongering/discouragement facts lol
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | weederr33 (03-27-2018) |
03-27-2018, 10:11 AM | #380 | |
Driving Coach
The Following User Says Thank You to ATL BRZ For This Useful Post: | CSG Mike (03-27-2018) |
03-27-2018, 11:12 AM | #381 | |
Sent from my SM-N950U using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
03-27-2018, 12:16 PM | #382 | |
BoostedBRZ
Drives: Turbo BRZ
03-27-2018, 12:18 PM | #383 |
BoostedBRZ
Drives: Turbo BRZ
how many tune revisions did the car receive to get it to where it's at now?
03-27-2018, 12:20 PM | #384 | |
Drives: brz 2017 hksv2
do you know how much power you had approximatively when you broke the rod? Cosworth says they tested the stock connecting rods and found 280hp is the maximum safe power, after that it s just lottery |
03-27-2018, 12:28 PM | #385 |
BoostedBRZ
Drives: Turbo BRZ
i was running the standard kraftwerks c38 standard pulley setup with flex fuel mostly running e75+. I never put it on a dyno, but if I could guess probably close to around 300whp. I should also add, I blew up at the track. I drove the car as a daily every day and drove it at the track. I always changed my oil specifically for track days, and then changed the track oil out for fresh oil. It was supercharged for a good 2 years 20k+ miles supercharged? when I did track it, it was over a weekend. probably 10+ 20 minute track sessions. 5 on saturday and 5 on sunday, sometimes a few on friday. So the car was beat on heavily for the entire weekend and then went back to be a daily. The track events were every other month or when i could afford it to put it into perspective. so I can't be too mad lol. It was fun while it lasted, but I sold the supercharger kit and am prepping for turbo.
03-27-2018, 12:36 PM | #386 |
Cosworth talked about 280hp , not whp, so you were well over the safe limit... and you got bad luck at the lottery eventually : ) oil doesnt count so much at this I think, the problem is the too much torque in a short time that could bend and breaks the rods easily
03-27-2018, 12:51 PM | #387 | |
We've seen them fail, even when hand picked for balance and internal structure (yes, we go that extreme) |
03-27-2018, 12:53 PM | #388 | |
03-27-2018, 12:56 PM | #389 | |
BoostedBRZ
Drives: Turbo BRZ
I meant to ask how many times did the tune have to be revised/ecu needed to be reflashed to be where it's at? (power numbers I don't really care about lol) I don't want to beat on a dead horse, but I feel like just as much as the owner is responsible for how they drive it, the tune also plays a key role in durability as well.
03-27-2018, 01:11 PM | #390 | |
BoostedBRZ
Drives: Turbo BRZ
03-27-2018, 02:18 PM | #391 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | pgranberg11 (03-27-2018) |
03-28-2018, 01:46 AM | #392 |
Drives: Panda FR-S
I've been daily driving e85 at this power level for 4 years and over 100k miles now. Vortech 3.48 pulley at like 8.5 psi max. High hp low torque. The blower doesn't come alive until 4k rpm, but if i'm banging through gears, I don't see below 4k. The stress on the motor down low is not that big of a difference than stock. Everyone scoffs at the vortech's torque when in reality it's the SC kit that makes the highest hp with the lowest boost pressure.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
Tags |
kill brain cells, not facts |
Similar Threads | ||||
FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 01:08 PM |
Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
