Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-18-2012, 12:56 PM | #15 |
Drives: 1994 BMW 318i
04-18-2012, 01:01 PM | #16 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
After driving the car, I can say with a good degree of confidence that it feels almost as good as the RX8 as far as feel and 'weight' go. Im of the opinion that the RX8 turns in quicker though.
Believe me, comparing this car to an RX8 is quite the complement, for all the failure in marketing and engine life that the RX8 is attributed with, its still one of the best handling cars under $40k. |
04-18-2012, 02:03 PM | #17 |
I'm afraid the Elise may be the last car offered with manual steering. Sub-3,000lb cars really don't need it IMO. As long as the EPS doesn't feel like it does in modern Corollas I'll be OK.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
04-18-2012, 08:29 PM | #18 |
Drives: 2013 "AVO Orange" FR-S
The steering most likely feels "light" to those drivers because of skinny tires, lightweight car, and not having the engine sit in front of the wheels. Once everybody throws on their wide and sticky summer tires, you'll appreciate the power steering when it comes to low-speed traffic and parking.
Regards, Paul Hansen www.avoturboworld.com www.facebook.com/BRZSportsCarClub |
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post: | cf6mech (03-04-2013), SilverSkyline210 (03-03-2013) |
04-19-2012, 05:55 AM | #19 | |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
Though I can almost guarantee that Toyota have "fixed" this for the GT86, as I haven't heard a single complaint from any of the reveiws about the EPAS being bad. Not to mention EPAS is also used in the LFA (though obviously a different version), and that's supposed to be plenty good to drive!
03-03-2013, 06:33 PM | #20 |
Drives: 2013 BRZ Limited / 2009 Boxster S
This is what you want: http://www.autospeed.com/cms/article.html?&A=111532
The Following User Says Thank You to kertong For This Useful Post: | hobojoker (05-17-2013) |
03-03-2013, 08:13 PM | #21 | |
Drives: Sonic Blue 86GT Manual
My MR2 has no power steering and while it's fine at higher speed, it's a bit crap at low speeds |
03-03-2013, 09:46 PM | #22 |
Seņor Member
Drives: 2013 Raven, Drifty things
Oh my god people if you haven't driven the car don't comment on how the steering is "light" or how all electronic assist programs are horrible....unless your previous daily driver is completely unassisted or a go kart you are probably going to love the steering's weight. Any sloppiness is from the high sidewall stock tires. Just like what AVO said. No, it isn't going to feel like an unassisted rack and pinion, unless it's an unassisted rack and pinion.
Anyway, for OP, it sounds pretty sketch. I think there's a lot easier ways to improve feel, such as poly bushings, lower profile/harder sidewall tires, more front camber, a strut bar. Sometimes to improve one thing you have to improve everything around it.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
03-03-2013, 09:49 PM | #23 | |
Drives: Perrin/VORTECH Supercharger TestBRZ
'right' |
03-04-2013, 12:04 AM | #24 |
Drives: FRS Silver LS1 swapped.
I'm more concerned with the light gas peddle feel, if you go boosted and hit a few bumps at slow speeds your in for a jerky ride....manual of course.You go with wider tires the steering is perfect.
03-05-2013, 05:33 PM | #25 |
Drives: SOLD...
My old echo didn't come with power steering, and it was real heavy once I put the summer wide wheels and tires on it. My yaris has the power assist, and I hear its as simple as removing the fuse if you want to feel what its like.
Check the fuse box perhaps it can be done with the FRS/BRZ (don't have mine yet)
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND |
03-31-2013, 05:54 AM | #26 |
Drives: Toyota 86 GTS White
Hey all - just came across this thread via a google search. I recently posted about my brand new 86 having very light steering all of a sudden. To the point where it has little resistance or driver / road feedback. I also feel as though there is lag between me turning the wheel and the car actually responding. Finally, I feel I have to turn the steering wheel way too much for the resulting steer amount. One day it was fine, the next day it was lazy/light and vague.
I have tried various tyre pressures, all no affect. It honestly feels like the EPS system is messing up. It feels like it is giving me assistance to stop the wheel from being heavy, but it's not actually assisting in turning the car's wheels.
Toyota 86 GTS Pegusus White
03-31-2013, 06:21 AM | #27 | |
Drives: White '17 86
The FR-S' power steering is fine. And yes it is parasitic, but you wouldn't notice a difference. Why? because the alternator only outputs a fraction of power that the engine can produce. Why didn't they go with a hydraulic steering pump? That would suck the power out of that little engine. Why did they choose the electric power steering? Because it didn't take too much power away from the engine. You can test whether the electrical power steering, AC unit, rear defroster, and what not are sucking power away from the engine. Let it idle, move the steering wheel back and forth. Does the rpm dip? when you turn on the AC unit, does the rpm dip? when you turn on the rear defroster, does the rpm dip? Most of those will be yes, but negligible when you are red lining it. If I took the motor that does the power steering assist, I could tell you how much it is really sucking from the engine. |
03-31-2013, 07:20 AM | #28 | |
That Guy
Drives: 2013 asphalt FRS MT
You might want to look at your control arm and/or steering rack bushings. |
Similar Threads | ||||
How do you guys feel about lifted trucks? | Guff | Off-Topic Lounge [WARNING: NO POLITICS] | 219 | 06-20-2019 01:24 AM |
What is your prediction on FT86 power and Subaru 086a power? | 86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 08-26-2013 11:49 PM |
Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) -- General Topics | 8 | 12-08-2011 11:16 AM |
Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
Feel like a Post Whore. | Siriusly.Andrew | Off-Topic Lounge [WARNING: NO POLITICS] | 60 | 03-14-2010 05:42 PM |
