Old 05-27-2014, 11:58 AM   #15
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
Originally Posted by marcoaferrer View Post
@draggin_az did you ever use the 3.125 pulley or did you go straight to the 2.87?
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-27-2014, 12:35 PM   #16
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
gotcha. Im trying to gauge the difference between 2.87 and 3.125. Dont know if its worth the trouble in my application.
marcoaferrer is offline   Reply With Quote
Old 05-27-2014, 12:45 PM   #17
ModBargains.com
ModBargains.com's Avatar
Lots of good info here, thanks OP for posting that up
ModBargains.com is offline   Reply With Quote
The Following User Says Thank You to ModBargains.com For This Useful Post:
marcoaferrer (05-27-2014)
Old 05-27-2014, 01:05 PM   #18
draggin_az
draggin_az's Avatar
right on.
I have no idea but if you're ever in va beach, you're more then welcome to drive it.
maybe the next goal could be getting up a dyno chart comparing the different pulleys (similar to how they did with the differnt superchargers)
277hp 93 octane
370hp on E-85
Old 05-27-2014, 01:37 PM   #19
marcoaferrer
that sounds like a step in the right direction. Right now Im working on putting together a list of different sites/third party suppliers and rebuilders for vortech blowers. I am also hunting down a pdf with the instructions on rebuilding the blower. I have it somewhere on my comp.
Old 05-27-2014, 01:48 PM   #20
draggin_az
draggin_az's Avatar
that sounds awesome and thank you for putting this thread together. it's already helped me out.
277hp 93 octane
370hp on E-85
The Following User Says Thank You to draggin_az For This Useful Post:
Old 05-27-2014, 05:36 PM   #21
marcoaferrer
Called Vortech so I could get detailed specs on the blower that werent available on their website.
New section has been added to the main post.
v3-H67B Blower Specs
Old 05-27-2014, 06:10 PM   #22
Dezoris
Dezoris's Avatar
Updated Post 4: Oil Temps and Used Oil Analysis.
Old 05-29-2014, 04:57 PM   #23
marcoaferrer
New section added to main post
Third Party Parts Suppliers / Rebuild Services
Old 05-31-2014, 06:18 PM   #24
DJCarbine
Thupercharged
DJCarbine's Avatar
Found some Goodyear Gatorback belt part numbers that will work with our superchargers
4060970 replacement for K060970
4060967 replacement for K060966 (within .1")
These belts seem to do well with superchargers from what I've read on other forums
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
marcoaferrer (05-31-2014)
Old 05-31-2014, 08:15 PM   #25
marcoaferrer
Awesome I'll update the main post when I can get to a computer
Old 05-31-2014, 11:18 PM   #26
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Can someone make up a chart for the v2 as far as what pulley= what rpm and what is the max rpm for the v2 vs the v3. I'm thinking of upgrading to the v2 from my v3
Rocket.BRZ is offline   Reply With Quote
Old 06-01-2014, 12:07 AM   #27
marcoaferrer
Are you looking to upgrade because your looking for more boost? Or because your going to running the blower at high rpm for an extended period of time?
Old 06-01-2014, 01:55 PM   #28
Rocket.BRZ
I just want more boost.
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 11:45 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 01:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
