08-15-2015, 08:19 PM | #617 |
義理チョコ
That's a little disconcerting. If it only happens while it's running, I'm leaning more towards binding under the bell housing.
08-15-2015, 08:40 PM | #618 | |
義理チョコ
Or, possibly, because travel of the throwout bearing is decreased, it may be hanging up on an already damaged transmission front cover. There have also been reports of friction plates binding on the input shaft. It's all conjecture unless the problem can be reproduced at will.
08-15-2015, 09:05 PM | #619 | |
義理チョコ
09-02-2015, 07:38 PM | #620 |
Drives: white-out FR-S
Which way do u turn the rod to have higher engage point. My engagement point is low near the end of peddle travel.
Sent from my Nexus 5 using Tapatalk |
09-02-2015, 08:22 PM | #621 |
Drives: 15 FR-S Firestorm MT
I don't quite remember, but you can lay a flat ruler on the brake pedal as a reference point. You'll be able to see the clutch pedal rise/lower better that way.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
09-02-2015, 08:42 PM | #622 |
Pedal rising high = higher engagement point?
09-02-2015, 08:45 PM | #623 |
Yup, you got it.
09-03-2015, 12:24 AM | #624 | ||
義理チョコ
For all reading this: The piston in the master cylinder MUST be allowed to fully extend when the pedal is released. Quote:
09-04-2015, 08:01 PM | #625 | |
09-04-2015, 08:07 PM | #626 |
09-04-2015, 09:45 PM | #627 |
義理チョコ
09-05-2015, 03:01 AM | #628 |
Drives: RX-7 / BRZ
Anyone had an issue with adjusting it too far? I did mine so it was flush with the brake pedal. The clutch engagement is almost instant however it is nearly impossible to spin the tires in 1st gear with a 3.5k drop. If I drop the clutch at 3k it grabs and then it takes a few seconds to bring the rpms up. It isn't stalling just seems like a long delay.
I'm thinking I adjusted too far? However the clutch isn't slipping nor is it dragging. I also have no slippage WOT and under power which is why I don't think it is the clutch slipping, and more the engagement point be incorrect. Just wanted some thoughts before I mess with it tomorrow.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
09-05-2015, 02:33 PM | #629 |
09-05-2015, 03:43 PM | #630 |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | yaguphire (09-05-2015) |
Tags |
clutch adjustment, clutch helper spring |
Similar Threads | ||||
power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
