09-23-2016, 02:40 PM | #1639 | |
Drives: 2013 Black BRZ Limited
No idea how this might fix my lean condition, given that other people on same or older configurations haven't had my issue - but I'll give it a shot. |
09-25-2016, 02:49 PM | #1641 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Got around to putting the HPFP cover back on. That damn pump is too noisy! Took a little hack 'n mod to clear the new banjo bolt position and to keep the 2 tabs from hitting the intake runners.
The Following User Says Thank You to BirdTRD For This Useful Post: | BigFatFlip (09-25-2016) |
09-25-2016, 05:27 PM | #1642 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
09-25-2016, 07:33 PM | #1643 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
09-26-2016, 01:37 PM | #1644 |
Drives: 2015 CWP BRZ Limited
^^ agreed. is the tune supposed to be more efficient? better power delivery? anything like that? i was told when i got mine installed at the time that the tune was much more efficient than the original tune it came out with. hopefully this one is better as well!
The Following User Says Thank You to JGalp For This Useful Post: | shiumai (09-26-2016) |
09-27-2016, 10:49 PM | #1645 |
Drives: FRS Monogram
I'll let you know when I have it done. Swamped with work this week. Don't think I can get it done until early next week.
The Following User Says Thank You to FuzzyFunk For This Useful Post: | shiumai (09-29-2016) |
09-28-2016, 02:49 AM | #1646 | |
This is after the car has been warmed up and is idling in the driveway. I don't want to jinx myself but the new EO tune from Edelbrock looks like it's "fixed" my wacky fuel trims while idling. http://datazap.me/u/taiguy/log-14750...ata=6-10-11-27 |
09-28-2016, 08:43 AM | #1647 | |
Drives: 2014 Porsche Cayman S
Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
09-28-2016, 08:48 AM | #1648 |
I asked Mike at Edelbrock about the new EO tune and he replied:
"From a legal stand point, yes we suggest customers have the new E.O. certified calibration installed for CARB purposes. As for differences, we made some adjustments in the lower RPM’s (~Under 20% throttle) which affect drivability and fuel delivery. This should result in a smoother driving feel as well as increase gas mileage. Hp/Torque numbers remain the same as before."
The Following 7 Users Say Thank You to shiumai For This Useful Post: | BigFatFlip (09-28-2016), Bonburner (09-28-2016), CounterSpace Garage (09-28-2016), CSG Mike (09-28-2016), funwheeldrive (09-28-2016), paiceyfan (09-28-2016), TofuJoe (09-28-2016) |
09-28-2016, 06:21 PM | #1649 |
and I jinxed myself. the check engine light came on after 20 miles.
I tried to read the DTC but got a message stating OBD Error during reading DTCs: No response to OBD request. Great. |
09-29-2016, 12:26 AM | #1650 |
09-29-2016, 07:36 PM | #1651 |
The Following User Says Thank You to taiguy For This Useful Post: | Silverstar (10-18-2016) |
09-29-2016, 09:31 PM | #1652 |
Drives: Late 2014 Subaru BRZ
Sweet you got a vacuum leak?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
