Old 03-07-2014, 01:05 PM   #29
andrew20195
Drives: 2013 Subaru BRZ
Let's not forget BW fumbled the launch on those turbos so hard too - they were basically vaporware for two years or something IIRC?
Sometimes unexpected delays come up. But if the product is readily available now and works as advertised, this is no longer an issue.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
evo4g63 (03-07-2014)
Old 03-07-2014, 01:42 PM   #30
jamesm
Originally Posted by SmsAlSuwaidi View Post
seems like your keeping yours correct ?
Sent from my IBrick
no... still going to a 3076r, probably just not so soon . got some other things to take care of first (mainly traction lol).
Old 03-07-2014, 01:58 PM   #31
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
The BW EFR turbos are no joke. I can assure this setup will be solid.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 03-07-2014, 02:25 PM   #32
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Full-Race is pricey for what you get though I concede the quality is high. Their single-scroll kits aren't much less expensive than their twin-scroll kits and I still haven't seen a lot of data on the EFR turbos in Subaru applications. Let's not forget BW fumbled the launch on those turbos so hard too - they were basically vaporware for two years or something IIRC?
I never understood whats so special about EFR turbos...
Sent from my IBrick
Old 03-07-2014, 02:43 PM   #33
andrew20195
Sent from my IBrick
There's plenty of info on the Full-Race website. They're Borg Warner's "premium" turbo offering that incorporates many modern advancements. Basically a competitor to the Garrett GTX series.
The unique offerings are on the smaller end. Their internal wastegate design flows better than most traditional internal wastegates, and some are available with built in bypass valves, so you can design a more compact turbo system. Not sure how much that applies to our cars or what Full-Race is working on.
Old 03-07-2014, 10:10 PM   #34
KAR
Drives: Whiteout 6spd
I basically want 400whp on east coast 93oct pump gas.. I believe that will be the focus on this kit.. Daily 400whp.. Second thing is they want it to react as quickly as it can compared to a SC. This will also have an option for bigger turbos in your preference..
KAR is offline   Reply With Quote
Old 03-07-2014, 10:16 PM   #35
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
400whp on 93 is kinda high
U can achieve 400 easy with e85 tho
I love boost!!!!!!
Old 03-08-2014, 10:25 AM   #36
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by jamesm View Post
you can make more than 400whp with a 2871. i made 387 @ only 15psi of boost with a gtx2867r. the 28's can get you to 450+ nowadays. it's not your grandpa's disco potato .
400rwhp out of a gt2871 would be impressive. I was under the impression that those turbos even with a .83 a/r would fall off around 375rwhp.
And the " only at 15psi " is all relative. It might seem like a low number of boost but on any other low compression motor like the ej's, you would need 20+ psi to achieve that power. Turbo's seem impressive on this motor because of the high compression and great flowing heads, but in reality you're not gonna push more out of a gt28 on this motor than any other, a turbo car will only push what max hp the turbo can deliver.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 03-08-2014, 12:09 PM   #37
xwd
Full Race makes great stuff but "daily 400WHP" on 93 octane isn't realistic on this car. Not unless they are including a built short block with the kit. You'd have to run 16-18 PSI on most turbos to get there. "Daily 300WHP" is more realistic.
Old 03-08-2014, 12:55 PM   #38
jamesm
I understand the relationship between boost and compression. My point was that the 387hp run was at 15psi, where I can run up to ~24psi, so obviously 400whp is well within reach of the turbo.
Old 03-08-2014, 01:45 PM   #39
Tansey86
Tansey86's Avatar
I apologize if it seemed like I was insulting your intelligence, was not my intent. I agree that 400rwhp is easily do-able on a gtx28, not on a gt28 however.
The Following User Says Thank You to Tansey86 For This Useful Post:
jamesm (03-08-2014)
Old 03-08-2014, 02:56 PM   #40
jamesm
No problem... And yes I agree the old disco potato wouldn't be quite as productive as the newer gtx's. I think the most people saw with those back in the day was around 320-350. A 2871 would get it done, you'd just need a bit more boost I believe.
The Following User Says Thank You to jamesm For This Useful Post:
Dustin (04-19-2014)
Old 03-08-2014, 10:50 PM   #41
KAR
Will do piston n rods once it gets back to jersey.. I will push it to its limits..
So yes 400 will not be a far fetch for me..
Old 03-08-2014, 10:53 PM   #42
Mustang88_357mag
Mustang88_357mag's Avatar
Drives: 2013 FRS Raven color
Full race is the kit I will go with when I turbo mine, I had their kit on my 01 ITR and it was amazing
Mustang88_357mag is offline   Reply With Quote
>>Circuit Motorsports - Full Performance Shop - Central FL / Orlando - 86 Specials << Circuit Motorsports Southeast 204 10-05-2016 01:27 PM
Full Blown Motorsports Base Turbo Kit with e85 Upgrade TyperRspec789 Engine, Exhaust, Bolt-Ons 24 07-12-2013 04:58 PM
Full Blown Motorsports Turbo Kit INSTALLATION at Real Auto Dynamics! Kevin@RAD Forced Induction 70 04-24-2013 08:47 PM
Indy Car and Grand Am Race at Barber Motorsports Park naikaidriver Southeast 5 04-07-2013 05:05 PM
Shannonville Motorsports Park Full Track August 11, 2012 funcheung CANADA 5 08-13-2012 11:54 AM
