Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 12-30-2019, 05:49 PM   #169
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Originally Posted by weederr33 View Post
I have some high temp RTV sealant. I just need to take the time to clean all the gunk and then patch it.
I remember seeing this post a while back in where someone had success patching it: https://www.ft86club.com/forums/show...5&postcount=24
Definitely would give it a shot.
Si_Chris is offline   Reply With Quote
Old 12-30-2019, 06:59 PM   #170
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Yup! That's the post I saw that gave me the idea
MS, CSCS, TSAC-F, CPT
Old 01-25-2020, 09:39 PM   #171
Payload
Drives: Raven black manual transmission
It looks very nice. So about how much power are you getting out of this yellow brz ??
Payload is offline   Reply With Quote
Old 01-25-2020, 09:43 PM   #172
KR-S 86
Sporadic Member
KR-S 86's Avatar
Drives: 2016 Halo FR-S M/T
Probably more than your FR-S.
Originally Posted by klearfade View Post
Is that gel in your hair?!
Originally Posted by HueyLooie View Post
Nah, homes. It's your dadda's hot goopey goop.
KR-S 86 is offline   Reply With Quote
The Following User Says Thank You to KR-S 86 For This Useful Post:
ROFL it's Waffle (01-29-2020)
Old 01-25-2020, 10:01 PM   #173
weederr33
weederr33's Avatar
Oh no not you....
Idk about power since I haven't dyno'd it.
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
KR-S 86 (01-25-2020), ROFL it's Waffle (01-29-2020)
Old 01-25-2020, 10:05 PM   #174
KR-S 86
Sporadic Member
KR-S 86's Avatar
Oh no not you....
In before this guy tells you what you should put in your car.
Old 01-26-2020, 03:26 PM   #175
weederr33
weederr33's Avatar
While changing my oil, I finally installed a fumoto drain valve! I was very hesitant at first as I could not determine the clearance of the valve to the skid plate. But there is roughly a 1/4" of space. And while I do have some scuffs on my plate, they are all from a single extreme moment of evading an object. I look forward to seeing how this does on my next oil change!
Old 01-29-2020, 07:15 AM   #176
Payload
This drain valve definitely looks like it fits within the skid plate clearance space.. It also looks nicely installed.. Good job.
Old 01-29-2020, 08:33 AM   #177
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: 2017 WRX (sold), 2009 Lexus LS460
I am extremely pleased with this product. I installed these on all of my cars. I think the valves with the nipple on the end are meant more for vehicles with higher ground clearance (more than 6 inches). I used to be in the habit of buying a new drain bolt, because for some reason the bolts start to round off on me (I only use 6-sided wrenches, never anything else, and "I don't think" I was torquing them beyond spec, but DYSLEXIA, so...).
I will say, my first time using it, I forgot to close the valve, so I dumped a quart of new oil into my drain pan before I realized it "man, this car is thirsty..."
Also, that plastic piece that "secures" the valve lever, this is a new addition (my Lexus has this too). I never had a problem with the valve "just opening up." I think Fumoto did this just to pacify some of the skeptics.
ROFL it's Waffle is offline   Reply With Quote
Old 01-29-2020, 11:12 AM   #178
weederr33
weederr33's Avatar
The plastic retainer does make me feel safer.
I also look forward to draining my oil now! I'll probably get the drain tube before I do it.
Weederr's Cosworth Supercharged Raven weederr33 Member's Car Journals 231 07-06-2017 10:21 AM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Audio/Visual, Electronics, Infotainment, NAV 0 05-12-2015 12:14 PM
10 Series / Series.Blue rear view mirror 86-ADL Cosmetic Modification (Interior/Exterior/Lighting) 4 11-16-2014 08:32 PM
BRZ series.blue/FRS Series 1.0 photos Johnny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-25-2014 11:23 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
