Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-02-2014, 04:01 PM | #1 |
Drives: 2013 frs
Frs temperature gauge question
Hi guys it's me again
Got a small question So today I went to go pick up my girlfriend from work and my car is warmed up, the gauge is reading just a bit under the normal So I park the car and let it idle so it can warm up more while I wait for my girl to come out But then I notice the Guage gets lower ( first line after the c) instead of warmer Is this normal? As soon as my gf came out, I went to drive the car and let it warm up to normal temperature. Now I'm inside the car and the reading stays at normal. And now going lower Thanks guys Sent from my SM-N900W8 using Tapatalk |
01-02-2014, 04:40 PM | #2 | |
Drives: 2013 Scion FR-S Ultramarine
Factory temp gauges are terribly inaccurate anyways, so it's nothing to worry about.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
The Following 2 Users Say Thank You to Xinshadow For This Useful Post: | humfrz (01-03-2014), Young_makaveli (01-02-2014) |
01-02-2014, 04:42 PM | #3 | |
Drives: 2013 frs
Appreciate it, glad that it's normal Sent from my SM-N900W8 using Tapatalk |
01-03-2014, 01:19 AM | #4 | |
Your car will normally "throw you a code" if it's ah ailing .... I suggest you pay more attention to your girlfriend .... she is more fragile than your car..... humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | onefitz (01-03-2014), Young_makaveli (01-03-2014) |
01-03-2014, 01:48 AM | #5 |
Drives: Raven FR-S 6M
I noticed my gas gauge goes down when I drive. Is this normal too?
“The World is Flat”
[||•]=(86)=[•||] |
The Following User Says Thank You to Apoc For This Useful Post: | wparsons (01-03-2014) |
01-03-2014, 02:08 AM | #6 |
Drives: 2013 frs
01-03-2014, 08:30 AM | #7 |
Sadly yes. Sometimes it's the only fun I have.
“The World is Flat”
[||•]=(86)=[•||] |
The Following 2 Users Say Thank You to Apoc For This Useful Post: | ftc~brz (01-03-2014), Young_makaveli (01-03-2014) |
01-03-2014, 03:56 PM | #8 |
Drives: 2013 frs
01-03-2014, 05:08 PM | #9 |
Thermostat should keep the temp in the normal range after the initial warm up. If it's cold outside it regulates the amount of coolant that's being circulated through radiator. So unless it's so cold outside that the engine can't get up to the working temperature with fully closed thermostat, it seems that the thermostat is not working correctly.
With the car being so new though, that seems very unlikely, so I'm not sure what it could be. |
01-03-2014, 05:11 PM | #10 | |
Drives: 2013 frs
But after I drove for a bit and let the car warm up,it didn't do the problem again Sent from my SM-N900W8 using Tapatalk |
01-03-2014, 05:25 PM | #12 | |
Drives: 2013 frs
[quote=toeout;1428154]
Similar Threads | ||||
What temperature do you put A/C on? | FRiSson | New England | 23 | 06-13-2016 08:55 AM |
P3 Gauge Question | jjkerr626 | Software Tuning | 1 | 01-01-2014 01:41 AM |
FA20CLUB FR-S/BRZ Gauge Integration- Install other sensors question | mtimney | Electronics | Audio | NAV | Infotainment | 2 | 07-24-2013 03:27 PM |
FS: AEM 30-4402 Oil/Transmission/Water Temperature Digital Display Gauge. | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 4 | 03-25-2013 10:37 AM |
Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) -- General Topics | 40 | 08-19-2012 04:29 PM |
