Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-28-2013, 07:01 PM | #15 |
That guy
Drives: Ultramarine mt FR-S
Had a typo there. The redline is the full P&L exhaust with high flow catted header, and catted midpipe. The blue is the same exhaust, just swapping out to an uncatted header.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
04-28-2013, 09:06 PM | #16 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The "goofy" longitudinal g chart is a direct representation of the torque curve (upside down) if done proper. I've confirmed this on the dyno many times, and you can clearly tell when the torque dip is gone. I have dozens of dynos and hundreds of datalogs that confirm this....simple math if executed properly. The said header will get dyno'd when we get time.
Now as to why the a proper header gets rid of the dip, it comes down to scavenging and runner lengths. Yes, you do move it to some extent, but when you have good collector, correct primary length/size, you end up making more HP overall so when you move the "dip" to another area, it simply becomes a global increase with the gains focused on the low end. The smoothness here is all important. Opposing runners are bad, and unequal is just fine as long as the runners from each bank are similar lengths. The tune then becomes all important because the exhaust cam timing is directly calibrated to the scavenging of the stock header. So here we will see how much more we can make on the dyno as the g meter is only good for curves not fine tuning. I suspect it will be quite significant since the stock cam profile "gives up" in the dip, and with proper header that means we have room to shove some more air/fuel in there. I doubt the cat itself is the issue. At least until you put it on a racetrack and it melts... |
04-28-2013, 11:00 PM | #17 | |
That guy
The goofy comment was not the best choice of phrase. Sure it's great for tuners who know what they are doing, but for the rest of us, it's not as easy to read. I was simply supporting the fact that the other headers he's making note of have been fully tuned, while I've yet to see a dyno showing the JDL header that has been tuned, so it's comparing apples to oranges, and not an accurate comparison.
Ultramarine mt FR-S
04-29-2013, 12:53 AM | #18 | |
Automotive Connoisseur
Drives: too many cars
LSx Powered 86/ASE Master Certified Automotive Technician
04-29-2013, 07:56 AM | #19 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
JDL FTW
Powered by Vortech, ECS Tuning, and JDL Auto Design
04-29-2013, 01:18 PM | #20 | |
What you were describing is definitely two physical cam profiles, like VVTiL or VTEC. You'll never get behavior like that from variable timing alone.
04-29-2013, 01:44 PM | #21 | |
04-29-2013, 02:05 PM | #22 | |
How's the p&l header for daily driving? Is it raspy/load at all? I've heard some negative things about it in the p&l thread noise wise. |
04-29-2013, 02:23 PM | #23 | |
That guy
Initially I took it off to get it coated, then packed it off to Gem for testing/fitment with the vortech kit, had a new one built, went on vacation and couldn't get my car in wile it was out, so I passed on it so P&L could get a few more orders out etc.. I will have it back on the car permanently on friday. It is a bit louder with an aftermarket exhaust, but it all depends on what exhaust you're running. My car seems quiet compared to @CircuitJerk, but He has the SRT exhaust, and that thing is rowdy as just a catback. Once the header goes on, I will be doing a little exhaust modification, adding in a larger, or second resonator because I have a low noise tolerance level for my DD cars, however, we do have video of my car with the full P&L exhaust, and will record more once the header goes on. We will also use a DB meter for measurements in, and out. There were a lot of people asking me for that, and I want to make sure they get the information they want.
Ultramarine mt FR-S
The Following User Says Thank You to Hawaiian For This Useful Post: | Sonolin (04-29-2013) |
04-29-2013, 03:44 PM | #24 | |
At first you said it's because there are two cam timing "profiles" (not cam profiles), one for lower engine speeds and one for higher engine speeds which have the ability to change flow characteristics. Now you're saying it's load based (as far as I know, the maps are actually speed and load based) and can't change flow characteristics. In any case, the cam timing is not to blame for the torque dip, it's all about airflow into and out of the engine. Since Nameless actually totally reversed the dip (they got like 40wtq gain at the worst part of the stock dip) with their long tube header, it's safe to say the header is playing a big part in it.
04-29-2013, 03:50 PM | #25 | |
04-29-2013, 06:15 PM | #26 | |
I just Drive.
Drives: in the womb still
I will stand behind you as well in how cam timing works. What I think is the problem is a combination of the stock exhaust manifold and the physical cam lobes/timing. The header takes away the dip because it may get rid of back pressure causing a pressure wave or some magic unicorn theory. However if you changed the cams without a header it may do the same thing.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
04-29-2013, 09:40 PM | #27 |
When you see aftermarket cams come out, the dip will look like it's gone because to get high end power it's going to sacrifice low end power, likely all before the dip making it look like a smooth increase instead of a spike/dip/spike.
I still stand by the stock header being the biggest contributing factor to the dip, there's too many dynos of good headers showing drastic improvements to not feel that way. From the nameless header thread, the 4-2-1 prototype with stock cams/heads:
The Following User Says Thank You to wparsons For This Useful Post: | mad_sb (04-30-2013) |
04-29-2013, 11:25 PM | #28 |
Drives: Scion FR-S
In my opinion, the reason for the torque dip is because the computer is on the motor. I've heard from a Toyota technician that when a car has it's computer on the engine it can cause problems. He suggest to buy a heat shield for it. This is the first time I've read that headers are helping the problem out.
Similar Threads | ||||
Figured I would share this April 28th | celek | NY / NJ / CT / PA | 0 | 04-08-2013 01:57 PM |
Apparently you can fit 4 wheels/tires in this car | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 03-31-2013 08:36 PM |
Has anyone figured this out yet? | chrisrefaei | BRZ First-Gen (2012+) -- General Topics | 16 | 10-26-2012 04:52 PM |
towed at 717miles CEL severe shaking (apparently a huge issue) | gdi2290 | Issues | Warranty | Recalls / TSB | 45 | 08-31-2012 10:25 AM |
Front seatbelt shoulder guides apparently an issue for passengers | Mr 286 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-01-2012 07:49 PM |
