Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
03-04-2018, 07:17 PM | #1 |
Drives: Asphalt FR-S MT
Weird sound from HVAC
Strange sound coming from the HVAC. Sounds like it’s coming right from the front vents. Even when the air is turned completely off. Any thoughts?
03-04-2018, 07:55 PM | #2 |
Drives: BRZ DGM Limited
Haven't heard that one before. Does it change if you have the blower motor running?
03-04-2018, 08:39 PM | #3 |
Good question, short answer is no.
changing the airflow from off to 1,2,3 or 4 makes no difference in the sound. Yeah I’ve been on this forum for years and I’ve never run across this sound before. It’s freaking me out |
03-04-2018, 10:35 PM | #4 |
義理チョコ
That's the cooling fan in the radio.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (03-05-2018) |
03-05-2018, 12:31 AM | #5 |
Is the sound that you are hearing, sound like a lamb bleating off in the distance ... ??
humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Kronos (03-06-2018), thatfilipinoguy (03-05-2018) |
03-05-2018, 06:02 PM | #6 |
As @Ultramaroon said I'd put money on the two (or one) little 60-80 mm fans in the head unit. Sounds like a bad bearing in them. Removing the radio is quite easy to check and isolate the sound. Also I'm assuming they're PWM type fans so they could be an easy fix without replacing the head unit
03-06-2018, 03:40 PM | #7 |
Oh so there are actually little fans in the headunit?? I legit thought @Ultramaroon was just trolling
Thank you guys for the advice. I will definitely pull out the unit and check. It was really starting to get to me. I was starting to seriously consider the bleating lamb theory @humfrz i loled |
03-06-2018, 03:46 PM | #8 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (03-06-2018) |
03-06-2018, 06:16 PM | #9 | ||
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (03-06-2018) |
Similar Threads | ||||
weird sound when accelerating in low RPMs | evoto86 | Engine, Exhaust, Transmission | 37 | 12-18-2020 02:40 PM |
Weird sound over 60mph | FRiSson | Issues | Warranty | Recalls / TSB | 23 | 03-05-2018 11:47 AM |
engine got weird sound | hands0me | Issues | Warranty | Recalls / TSB | 14 | 07-29-2016 06:07 PM |
weird engine sound | Stratoside | Issues | Warranty | Recalls / TSB | 52 | 01-13-2016 03:05 PM |
This might sound weird | mrha | BRZ First-Gen (2012+) -- General Topics | 10 | 10-06-2012 06:06 AM |
