Software Tuning Discuss all software tuning topics. |
06-20-2014, 02:57 PM | #29 |
Dont forget you get $100 off on the OFT if you come from Ecutek
06-20-2014, 05:37 PM | #31 |
I believe James is referencing the 2.048ml injection limitation that the ECU seems to have. I know you could mis-calibrate (hack) the port / direct injectors to inject the wrong amount of fuel in which you would need to tweak a lot of tables to work properly as the calculated injection would be incorrect. This just may not be something everyone would be wanting to do lol. I don't know anyone with open source / oft that has pushed to the 2.048ml injection wall yet to see if it is ecutek related or just ecu related. Unless maybe you have?
On my own car I had to use a custom map in ecutek to inject past 2.048ml while on higher boost levels as the ecu would stop increasing the port/di open time at a certain point.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
06-20-2014, 06:01 PM | #32 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Maybe i missed something but i dont believe their has been a dyno comparison for base maps using ecutech vs OFT for this stg 1 package they are promoting. Lets wait for that before judgement. Then you two can start the next world war
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
06-20-2014, 06:06 PM | #33 |
His comment has nothing to do at all with a basemap and has to do with fuel injection limitations of this ecu that a number of us have been working with. But not everyone is trying to push that much on E85 some people are just wanting a tad more power in which it should work just fine.
06-20-2014, 07:14 PM | #34 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Sigh... why would you need custom maps to overcome what is likely a hard set threshold, scalar or limitation of the data format (8bit or 16bit) - unless you really like doing things in a convoluted, round about way?
I'm betting that it's this value that simply needs to be bumped up: Code:
ROM:00059FD0 flt_59FD0: .float 131072.0 Or more neatly, as I've pointed out before, there seem to be two scalars that are used for the injector flow scaling in the BRZ, and it seems that it is the practice to change only the one - I'm betting that leaving the other at the standard value: Code:
ROM:0010DDDC Injector_Flow_Scaling:.float 12176.6 But yeah, I guess you could bypass the standard control logic of the ecu using custom maps tacked onto the main control routine, and achieve the same aim. Like you could reach your right arm over your head to scratch your left ear. |
The Following 5 Users Say Thank You to Td-d For This Useful Post: | MFB (07-31-2014), MoogDiesel (06-21-2014), s2d4 (06-22-2014), Shiv@Openflash (06-20-2014), steve99 (06-20-2014) |
06-20-2014, 07:22 PM | #35 | |
Drives: 2013 FRS
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | mwjcyber (09-08-2014) |
06-22-2014, 11:43 AM | #36 | |
You're going to need custom maps to run more than ~2 bar manifold pressure, unless they've done some sort of modification directly to the rom. If anyone has managed to run more than that on a stock rom without custom maps, I'd love to see it. Really it's a moot point because you wouldn't be running that much boost without flex fuel and speed density anyway. |
06-22-2014, 12:48 PM | #37 |
Drives: White 2014 BRZ
06-22-2014, 12:59 PM | #38 | |
06-22-2014, 03:40 PM | #39 |
Well, that ticks off one item:
Limitation of the data format (8bit or 16bit) = the OBD routines convert the direct data, normally float, to either 8 bit or 16 bit (e.g. the DI pressure is fed out as 16 bit i.e. maximum of FFFF). That explains the 2.048 logging limit. This of course would be alleviated if you could just log the direct parameter. On the injection limit - I'm happy to work with anybody who would be running that kind of pulse width to find the limit / threshold. I'm sure we can modify the threshold or scalar 'directly to the rom' - not unlike modifying any other calibration 'directly' in the rom. |
The Following User Says Thank You to Td-d For This Useful Post: | Luckrider (06-23-2014) |
07-30-2014, 10:23 PM | #40 |
Drives: 2010 Nissan GTR
Wanted to share some good news, Vishnu will begin working on Free OFT Tunes for the Automatic Transmissions FT86 next week.
We hope to release those to the public in August Chris |
09-08-2014, 06:02 AM | #41 |
Drives: 2013 MT Asphalt FRS
Hope Shiv comes through with a tune once stg2 turbo comes out!
I really like how this kit looks in the engine bay and compatible with my OFT (: |
11-19-2018, 06:54 PM | #42 |
Drives: white frs
Is there an OTS tune for SDB kita for 2015 subaru brz . I cant seem to find it
Similar Threads | ||||
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
turbo tune dfw | bjun | Southwest | 31 | 10-22-2014 12:10 PM |
Scion FR-S Turbo Hybrid coming? | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 12-19-2013 09:25 PM |
Mackin FR-S Greddy Turbo Kit Install and Tune | Evasive Motorsports | Forced Induction | 5 | 09-06-2013 03:30 AM |
Shop in TN or MS to install and tune turbo | brocktwalker | Southeast | 2 | 03-16-2013 09:58 AM |
