12-11-2018, 02:51 PM | #15 |
Drives: Crystal white brz
Also is this the same engine you race with? How has it held up? How many miles? Thanks again!
12-11-2018, 02:54 PM | #16 | |
Brand New FA20 (never used/ran) Short Block 10.5:1 JE Pistons & Ring Kit https://www.jepistons.com/Products/315117.aspx CP Carrillo Rods https://www.summitracing.com/parts/cnn-s0248 KING Bearings XP for rod and main bearings http://kingracebearings.com/products...r-subaro-fa20/ WPC Treatment to pistons ARP engine case bolts I also have the heads for this motor, but they are not assembled to the engine right now because I was going to keep them for myself. They have a radius valve job and flow excellent (they are also new, but we copied the same profile as my other set of heads because they ran so well). The heads have supertech valves, and Piper Stage One cams - "Ultimate Road". https://www.counterspacegarage.com/piper-cams-stg2-fa20 The cams have 262 degrees of intake duration and 266 degrees of exhaust duration with 11.35mm intake lift and 11.30mm exhaust lift. These specs will give improved midrange and top end without sacrificing bottom end with the right tuning of the variable cam timing. Fully Built FA20 Long Block (ran for about an hour for break in - then it was taken out of the car and I put a fully stock engine in the car to get it ready to sell) 10.5:1 JE Pistons & Ring Kit https://www.jepistons.com/Products/315117.aspx CP Carrillo Rods https://www.summitracing.com/parts/cnn-s0248 KING Bearings XP for rod and main bearings http://kingracebearings.com/products...r-subaro-fa20/ WPC Treatment to pistons ARP engine case bolts ARP head studs Port & Polished Heads Supertech Valves Piper Cams - Rally Intake: 284 degrees Exhaust: 274 degrees with 11.35mm intake lift and 11.30mm exhaust lift. https://www.counterspacegarage.com/piper-cams-stg3-fa20 Please let me know which one you are interested in and I will give you my best price
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
12-31-2018, 03:15 PM | #17 |
bump
01-30-2019, 02:29 AM | #18 |
Bump
01-30-2019, 01:29 PM | #19 |
Drives: Bone stock
Just waiting on that tax money! Lol
Sent from my SM-N960U using Tapatalk |
02-03-2019, 12:16 AM | #20 | |
maybe someone will buy the racecar haha
02-07-2019, 08:03 PM | #21 |
Bump.
Long block sale is pending with deposit down. New built short block and performance race heads still available.
02-16-2019, 04:56 PM | #22 |
Long Block Sold. New short block and performance heads still for sale.
05-15-2019, 01:08 AM | #23 |
Drives: WRB 14 BRZ
How much for the short block?
05-15-2019, 11:54 AM | #24 |
Drives: Many
If still available, how much for the short block and heads?
Similar Threads | ||||
Suggestions on built short block and compression ratio? | SoCal80six | Forced Induction | 24 | 11-18-2015 05:59 PM |
Crawford Built Short Block | texasbound972 | Engine, Exhaust, Transmission | 26 | 05-15-2015 03:39 PM |
WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 01:26 AM |
WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 05:21 PM |
Built B18B Short Block | C130NAV | Miscellaneous | 0 | 01-04-2014 12:15 PM |
