Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
11-29-2018, 10:59 PM | #1 |
Heat is hot on driver side and cold on passenger.
I’m at a loss. When running my heater it is hot as ever on the drivers side vents but on passenger side it is Luke warm at best. It doesn’t happen with the AC. Coolant is full. I’ve checked the actuator and it seems to be fine. It doesn’t have the dual climate control. Any ideas on what to check next? 2013 Fr-s base.
Thanks |
11-29-2018, 11:20 PM | #3 | |
It's supposed to be the other way around, so as to keep your SO all toasty. Is the air flow the same on both sides? Are you talking about the floor vent or the dash vents or both? humfrz |
11-29-2018, 11:23 PM | #4 |
11-29-2018, 11:55 PM | #5 |
義理チョコ
Only difference between base model and dual climate controls are the knobs. The base model has a common control but the ducts are still separated. Something slipped or broke on the passenger side.
https://demos.starbase7.net/t3Portal...04PH8002X.html
Last edited by Ultramaroon; 11-30-2018 at 12:58 AM. Reason: added link to source |
11-30-2018, 01:22 AM | #6 |
Thank you, it’s work for me but passengers don’t like it lol. Air flow is the same and it is all vents.
11-30-2018, 01:23 AM | #7 | |
11-30-2018, 02:14 AM | #8 |
義理チョコ
It's going to be deep inside the unit itself. No easy way to get to it.
11-30-2018, 12:55 PM | #9 |
Similar Threads | ||||
Warm air drivers side, cold air passenger... | elitegunslinger | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 06-12-2018 10:23 AM |
heat on one side ice cold on the other? | DarkCard | Issues | Warranty | Recalls / TSB | 4 | 02-15-2015 03:22 PM |
Selling Buddy Club Side Mount Seat Rails (Driver and Passenger) | kseipel | Interior Parts (Incl. Lighting) | 0 | 07-02-2014 02:34 PM |
wtb brz driver and passenger side sun visors | nerdgsr | Want-To-Buy Requests | 3 | 04-29-2014 04:28 PM |
Teaking Tail light and Driver side passenger window auto down | feyrerm | Issues | Warranty | Recalls / TSB | 2 | 08-11-2012 12:32 AM |
