Old 10-09-2012, 01:00 PM   #85
Mechazawa
Drives: FR-S, 6MT, White
I think you could "tool" some veg tanned leather into a logo and just glue it over the scion logo with some contact cement, it wouldn't do any harm if it came off and smacked you in the face. Just have to decide what sort of logo to go with (toyota, 86, boxer emblem), given the shape we are stuck with, then the real challenge is to make the tool to put the impression in the leather.
Mechazawa is offline   Reply With Quote
Old 10-10-2012, 12:00 PM   #86
jadewbj
jadewbj's Avatar
This in leather would be awesome.
jadewbj is offline   Reply With Quote
Old 12-06-2012, 07:29 AM   #87
_F-R-S_
Drives: 13 whiteout scion frs
So if i take out these fuses will there be any chance the airbag goes off? Should i also take off battery?
_F-R-S_ is offline   Reply With Quote
Old 12-06-2012, 03:00 PM   #88
wbradley
Sarcastic SOB
wbradley's Avatar
If you put a Subaru emblem on there and then deploy the airbag you'll be seeing stars!
Thanks for the DIY if I ever want to swap out the wheel.
The Following User Says Thank You to wbradley For This Useful Post:
PrDarkKnight (01-18-2013)
Old 01-18-2013, 07:32 AM   #89
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
I can't seem to get to the clips mentionted any ideas?
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 02-12-2013, 06:49 PM   #90
Gixxer86
Drives: Scion FR-S (Asphalt)
I also pulled my airbag and had an issue at first... It is because there is a third clip on the bottom of the airbag. There is a hole that looks just like the ones on the side, and you just push the rod towards the middle of the steering wheel, just like you do through the holes on the sides.
Also... The fuses, all three, are for the horn according to the diagram on the back of the fuse box cover. None of them are for the airbag. With that said, i dont think it would matter much. People pound and lean on their horns in road rage, that's not what would set them off. Unless you short a wire or something, you should be fine. I would be more focused on making sure you support the airbag as you release it and pull it out so you dont damage the wires/connectors in the back.
To the OP: THANK YOU for the write-up, helped alot in wrapping the trim piece underneath the airbag :-D
Gixxer86 is offline   Reply With Quote
The Following User Says Thank You to Gixxer86 For This Useful Post:
Synack (02-18-2013)
Old 02-14-2013, 02:22 PM   #91
Gixxer86
just looked in the owner's manual... fuse 47, the blue 15amp fuse all by itself in the top left corner of the pic in the OP, That is the main Air-bag fuse... just a FYI.
Old 02-18-2013, 08:40 PM   #92
Synack
Boosted
Synack's Avatar
Drives: Sideways
I only recommend removing all said fuses for safety and the more than likely occurrence of accidentally unwanted honking of the horn.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 02-26-2013, 02:41 PM   #93
BRZ NA
Drives: WR blue
Is there is fuse for each airbag? I m wondering how can you disable the driver seat airbag or by pass it without effecting others.
BRZ NA is offline   Reply With Quote
Old 02-27-2013, 01:12 PM   #94
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
How heavy is the steering wheel airbag?
LeeMaster is offline   Reply With Quote
Old 03-22-2013, 03:19 PM   #95
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
@Synack: Regarding the picture below and instructions to "push that pin inwards of the steering wheel, while simultaneously pulling the airbag. Do this to each pin on both sides and pull the airbag out, it is semi-difficult."
Is that saying one side can be pulled at a time or do both sides need to be pulled while simultaneously pushing the pins on both sides? Also "it will open the hole above to allow the release of the airbag." What is meant by "open the hole"... am I supposed to be doing something with the top holes? I thought I'm supposed to be pulling on the airbag while pushing the pin in the lower holes.
Lastly, when reinstalling the steering wheel, is recalibration of the steering position necessary? That's what a Subaru service rep told me but I'm not sure if that would be true for this car since it looks like the wheel bolts into a set place with no room for play/adjustment.
Old 05-01-2013, 08:29 PM   #96
Willsonk
Drives: Scion FR-S Asphalt AT & XB
If you disconnect the battery ..... wouldn't that just shut everything down?
Willsonk is offline   Reply With Quote
Old 05-03-2013, 11:55 AM   #97
BRZ NA
Drives: WR blue
Just looking to disable the driver side only though
Old 05-09-2013, 10:32 AM   #98
Gen
Drives: Scion FR-S
Did anyone happen to snap a picture of the back of the airbag cover without the airbag in place?
Gen is offline   Reply With Quote
steering wheel controls inimitable BRZ First-Gen (2012+) -- General Topics 79 09-05-2016 12:56 AM
Anyone tried debadging the steering wheel? Synack Cosmetic Modification (Interior/Exterior/Lighting) 60 07-22-2013 07:18 PM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) -- General Topics 125 04-09-2012 08:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 06:17 AM
