Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
05-23-2012, 03:03 PM | #15 |
Drives: 2013 Scion FR-S Toyota 86
I'm experiencing this olin my toyoda rav4.. It's a year 97.. So guessin the temp control is broken or vent for heated air underhood is not closing fully.. Bring to service right away and let us know about it.
05-23-2012, 03:08 PM | #16 |
Drives: Asphalt MT FR-S
My 2004 Corolla S has always done this as well. Feels like the outside AC vents take a detour next to the radiator for some reason .
05-23-2012, 03:49 PM | #17 | |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Hopefully this isn't the case with the BRZ
Powered by Vortech, ECS Tuning, and JDL Auto Design
05-23-2012, 03:59 PM | #18 |
BTW you guys should change the vent setting to hot and maybe it will do the opposite
05-23-2012, 04:09 PM | #19 |
Drives: 2013 FR-S, Manual, Argento
Some cars are just that way, depending on how the underhood packaging, the exhaust pipe routing, and the HVAC ducting coincide with each other. My Miata's were always that way. The "vent" always issued warmer-than-ambient air, and having hot footwells was a very common pet peeve.
05-23-2012, 04:30 PM | #20 |
Drives: 350z Nismo, CBR1000RR
I've had a few cars that do this. It's probably due to the fact that the intake air has to pass firewall and then through the blower motor and all the plastic piping in the dash, so it has time to heat up.
05-23-2012, 04:41 PM | #21 |
Drives: 2017 Subaru BRZ PP
My Eclipse does this. It's not hot but a little bit warmer than ambient. Even when off it blows some air in so you have to redirect it or shut the vents. But I always have my windows open when it's warm out anyway. Unless it's warm and raining, then I turn the A/C on.
I'm kind of surprised this car would do this though. I thought that was something they fixed/changed with newer models. I wonder if it has something to do with Denso's system.
Toyota + Subaru =
05-23-2012, 04:42 PM | #22 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Must be a Toyota thing...(My Corolla does this too)
Here's my solution: Turn on A/C for awhile till the air is cold. Then turn off the AC a little later. the air should start to cool down somewhat but will stay coldish. I've always thought it had something to do with the ambient air temperature outside which its drawing the air from. The worst part is sometimes i get a nasty smell with the dial on Cold until i turn on the AC which gets rid of it. |
05-23-2012, 04:47 PM | #23 |
Drives: "I drives like a Porsche"
My Z used to do this but the heat would be coming from the floor.........after a few months it just stopped on it own.
05-23-2012, 05:01 PM | #24 |
Drives: Ducati 749 / Ktm Smc lc4 supermoto
My sister has a toyota camry 07 and it has the same problem since we first got it.. you could try before turning off the AC set the temp at a room temp(comfortable car temp) then turn it off. With camrys if you leave the dial on cold , and turn it off you will slowly feel the chill kick in.. Same goes with the dial on hot making your eyes dry out and a swamp in your seat
05-23-2012, 05:20 PM | #25 |
Drives: 2012 WRX Sedan
Also if it wasn't suggested already, check your oil, in regards to the knock.
05-23-2012, 05:21 PM | #26 |
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
With the AC off arent you just getting outside air blowing in with nothing cooling it?
05-23-2012, 05:22 PM | #27 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
This happened in my Maxima, as well.
05-23-2012, 05:39 PM | #28 |
Drives: future FR-S
I live in Texas and if the AC isn't on then you won't get cold air period. We can only use the fan with no AC in November.
Similar Threads | ||||
Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) -- General Topics | 59 | 12-01-2013 12:28 AM |
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 | Snoopyalien24 | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 11-26-2011 07:56 AM |
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 67 | 11-09-2011 05:58 PM |
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
