Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
12-25-2018, 05:16 AM | #15 | |
Drives: GR Corolla
I can't remember off the top of my head what the camber specs are, but I believe I put the front at the most negative setting the Flex Z offers, and the rear left was able to go within OEM spec, and for some reason the rear right was not able to and is around -1.9*. |
12-25-2018, 05:25 AM | #16 |
Drives: GR Corolla
Here are clearer pics of my set up. They're older pics, but the alignment specs are the same.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post: | Leonardo (01-14-2019), ryann.mendoza (03-07-2019) |
12-25-2018, 10:32 AM | #17 |
Drives: 2015 BRZ
Why don't you consider a 17x8 wheel? That way you can use a 215/45, 225/45, or a 245/40 size tire. It's the best compromise between your two sizes. As mentioned i wouldn't consider the TRD forged wheels as there are better options available. Also, if you do go for autoX then i would consider the 17x9 for sure but a 17x8 shouldn't be a problem with grippy tire either.
12-25-2018, 06:51 PM | #18 |
I second the 17x8 wheel size. Lots of good options. 3 of my favorite are RPF1, 949 6UL, and koing hypergrams.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | SuperTom (03-04-2019) |
01-14-2019, 01:11 AM | #19 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
03-02-2019, 07:02 PM | #20 |
Emperor McDuck
Drives: 2019 86 GT; 2018 BMW S1000RR
After giving this way too much thought and very nearly buying the wedssports, I ended up just getting some re-71r tires for stock wheels for now. At some point, I may get the TRD forged wheels, but decided against a larger width aftermarket wheel. This summer I will be doing a lot of autoxing and want to stay in C Stock class. Can stay there with the TRD wheels and can use the re-71rs with those if I want, but going wider would get me into modified class and I don't want to go there. Not a huge gain from the TRD wheels, would mostly just be a looks issue, so that's why I am holding off on those. I could do another 17x.5 wheel, but haven't found any I really like.
The Following User Says Thank You to xdavidx For This Useful Post: | why? (03-02-2019) |
03-02-2019, 07:20 PM | #21 |
Drives: Some rust bucket
@xdavidx, props for you driving an 86 and working an executive level job. Do you get any weird looks (serious question)?
I'd be more conservative and would be driving a Lexus/some boring car, but that's just me. |
03-02-2019, 08:00 PM | #22 | |
Ha, the site lead at my job drives a Golf R, if anything it just makes him more interesting. There are a bunch of AMG and M cars owned by the executives under him at work too. If he pulled up in a 488 that would be showing off. |
03-02-2019, 08:13 PM | #23 | |
An executive driving an impractical 2 door Toyota feels like it might raise an eyebrow. I just picture someone wearing a 2 piece suit getting out of a twin lol. |
03-02-2019, 09:34 PM | #24 | |
Emperor McDuck
You don't worry so much what people think about you when you realize how little anyone actually does. I get a lot more weird looks when I take my s1000rr |
The Following User Says Thank You to xdavidx For This Useful Post: | Tristor (03-02-2019) |
03-02-2019, 10:02 PM | #25 | |
Drives: 2017 Subaru BRZ Limited
03-03-2019, 09:57 AM | #26 |
How do you like the cg lock? This is the first car I plan to use one in since it real is a dual purpose situation for me.
Drive upgrades. Don't buy them.
03-03-2019, 11:05 AM | #27 |
Drives: jrsc_brz
fellow s1000rr rider here:
heres what you do get the 17x8 enkei TS-10 from tire rack ~$215/rim heres how they look on the 86: http://www.ft86club.com/forums/showthread.php?t=131551 put whatever tires you want on them, but youll ll be hardpressed to outdrive BFgoodrich Sport Comp 2's. thats a lot of tire for the price ($130) my ts-10's with sport comp 2's just showed up from tire rack, mounted and balanced baby! except i got gold rims, not black. black looks OEM+ make sure they send you the proper 56.1mm hub rings. they sent me 54.1mm thinking i was in a '19 corolla. |
03-03-2019, 08:28 PM | #28 |
Sort of off-topic, but basically it does what it says on the package. You may have trouble if you're a bigger guy with it digging into your side and it's impossible to carry a gun strong-side when you're using it, but otherwise it works good and does exactly what it claims and no more.
Similar Threads | ||||
FS:WedsSport TC105N 17x9 +35 w/ 235/40/17 RC1 4/32" tread remaining | CSG Mike | Wheels and Tires | 7 | 03-24-2016 02:37 AM |
SOLD 5x Weds Sport TC105n 17x9" +35 5-100 TS | mav1178 | Wheels and Tires | 7 | 12-12-2015 01:35 AM |
FS: WedsSport TC105N 18" Gunmetal - PRICE DROP! | EightySiiicks | Wheels and Tires | 26 | 01-17-2015 05:57 PM |
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS | BestWheelDeals | Wheels and Tires | 2 | 09-07-2012 09:26 PM |
