Forced Induction Turbo, Supercharger, Methanol, Nitrous |
06-05-2014, 10:34 AM | #57 |
Drives: A Car
@protpibe: Can I ask where you wired your grounds for the MTX-D gauge? Mine just came in yesterday, and I'm looking around under the dash to see which wires I can use. There are 3 black wires that should be put into a ground source, could I just put all 3 in one place?
06-05-2014, 10:49 AM | #58 | |
I think this was the thread I referenced when wiring my gauges http://www.ft86club.com/forums/showthread.php?t=28800
The Following User Says Thank You to protpibe For This Useful Post: | w3bhead (06-05-2014) |
06-05-2014, 10:53 AM | #59 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | w3bhead (06-05-2014) |
06-05-2014, 11:27 AM | #60 | ||
Drives: A Car
Sent from my C6833 using Tapatalk |
07-09-2014, 12:24 AM | #61 |
Drives: A Car
I'd like to get the opinion of anyone who has experience on this. I'm having doubts about the way I installed the oil pressure sensor on the sandwich plate since it wouldn't screw in all the way down compared to the oil temperature sensor, as you can see. It's already very difficult turning the sensor at this point and I didn't want to force it any more because I'm afraid it would break. Would it be fine like this? Both the sensor thread and the sandwich plate are 1/8 PT, and I applied some thread sealant before screwing both sensors in.
07-09-2014, 03:49 PM | #62 |
Drives: 2013 WRB BRZ
Go with the Prosport remote oil pressure sensor kit that has you connect it to the galley plug. I have the Innovate MTX-D dual oil temp/pressure gauge and it fits the relocation kit. Also I had space issues with the oil pressure sensor on the sandwich since I am running a KW S/C kit.
Second place is just the first place loser.
Dale Earnhardt |
07-09-2014, 03:54 PM | #63 |
Is that the GReddy sandwich plate? If so, it won't fit unless you have an oil cooler sandwich plate or spacer to go underneath. The sensor and temp probe may also be clocked wrong so they both may not fit.
I agree with the suggestion for the prosport relocation. I'm using it along with the gt86 Blitz sandwich plate. I couldn't get the GReddy to fit
The Following User Says Thank You to protpibe For This Useful Post: | cjd (08-23-2015) |
11-21-2014, 09:46 PM | #64 |
Drives: white premium brz M/T
Does the gallery plug read both oil temp and pressure or just pressure?
I've read through the entire post and I am still confused as to which it reads. Thanks in advance
11-22-2014, 12:04 AM | #66 |
Where's a good place to hook up the oil temp?
I got the innovate which reads both temp and pressure, and I'm trying to figure out where to connect the temp sensor.
11-22-2014, 01:45 AM | #67 | |
義理チョコ
Personally, I'm looking at sandwich plates as already mentioned in this thread. Not a fan because they seem a bit kludgey but I haven't yet found an alternative. |
11-22-2014, 10:47 PM | #68 |
I removed the stock oil pressure switch and use it for pressure and use the top location for temp. It reads slightly lower than the stock oil temp sensor. My pressure sensor seems to be on the fritz though, need to replace it.
The Following User Says Thank You to xwd For This Useful Post: | Ultramaroon (11-22-2014) |
11-23-2014, 11:27 AM | #69 | |
Drives: RX-7 / BRZ
You have 4 location where you can tap for oil temperature. Keep in mind if you have an oil cooler you want the sensor ideally not imediatly after the oil cooler but, closest location where the oil enters the block or your reading will always read cooler than they are. Also not some have stated that the top gallery plug on the block will read slightly hotter (only a couple degrees if any.) This was in comparison to the stock temp readings which are accurate. 1. Factory location, remove and replace with sensor. 2. Top oil gallery plug. Buy an adaptor and screw in. MAP sells a nice one for 1/8th NPT... 3. Tap the oil pan. There are some adaptors for the oil drain bolt but, that is very low IMO. 4. An oil fitler sandwhich/adaptor plate. If your gauge reads both temp and pressure then I'd personally consider removing the stock oil pressure gauge and installing the innovate gauge there. Then relocate the stock gauge to the top oil gallery plug and
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following User Says Thank You to Kiske For This Useful Post: | bjun (11-23-2014) |
11-23-2014, 03:49 PM | #70 | ||||
義理チョコ
Hey, now...
Then where do you put the more important sensor that feeds the ECU? Wasn't that developed around reading temps from that specific location? Quote:
Yes. Quote:
This leads us right back to the sandwich plate. Did I miss something? Last edited by Ultramaroon; 11-23-2014 at 04:05 PM. |
Similar Threads | ||||
S> Unichip + Download Cable ($300), Socal Preferred | l0aded | Engine, Exhaust, Bolt-Ons | 1 | 01-05-2014 06:17 PM |
Gauges - The best in monitoring devices! | Rev Works | Interior Parts (Incl. Lighting) | 1 | 07-28-2013 09:28 AM |
WTB: 2x Stock FRS/BRZ wheels (with tires preferred) LA area | retrosmiths | Wheels and Tires | 1 | 07-18-2013 04:21 AM |
Tyre Pressure Monitoring Systems | Fish Eagle | AFRICA | 3 | 07-14-2013 04:52 PM |
New Tire Pressure Monitoring Sensors? | Kochinopride | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 04-14-2013 08:51 PM |
