Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-21-2018, 02:22 AM | #15 |
It's all hooked into the lightweight pulley thing - it's all about rotating mass or lack thereof.
Like back in the day, when we would roll in the window wings, to reduce drag and turn on the heater, to help cool the engine, before the 1/4 mile drag on the country road … humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Strife26 (07-21-2018), x808drifter (07-21-2018) |
07-21-2018, 02:33 AM | #16 |
義理チョコ
07-21-2018, 02:36 AM | #17 | |
OK hands up everybody that ever had to turn the heater on in the middle of summer to cool the car. I probably did it several hundred times.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
07-21-2018, 02:38 AM | #18 | |
About quick shifting, when I'm in my FR-S and pitted against the soccer mom, on her cell phone, in a minivan full of kids, I NEED all the shifting speed I can get to beat her to the next light .. I remember back in the day, I had this old Chevrolet that had a vacuum assisted shift - which was smooth as silk, if you weren't in a hurry to shift. I decided that I needed to shift quicker when I was drag racing. So, just before this big race, one rainy night, against a flathead V-8 Ford, I pulled the hose on the shift assist vacuum can. NOW, the engine had ALL the vacuum to itself, but the distributor advance got all confused and the vacuum windshield wipers wouldn't work … but, man I could shift quick. Where did @Ultramaroon run off to tonight, he must be on a heavy date??? humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | chaoskaze (07-22-2018) |
07-21-2018, 02:52 AM | #19 | |
[ame]https://m.youtube.com/watch?v=OeKSnTxaE74[/ame]
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (07-21-2018) |
07-21-2018, 02:53 AM | #20 |
義理チョコ
Oh yeah. Many many times.
07-21-2018, 02:55 AM | #21 | |
Now, for you young-ens who never had to do that, the added heat inside the car wasn't actually all that noticeable. Why? Because, we didn't come out of an airconditioned house and our cars weren't air conditioned, and it was 90 degrees outside with 85% humidity and we had worked in a hot hay loft all day with unsteady flooring and a tin roof, with hay chaff down our back and nothing to eat all day except peanut butter and jelly sandwiches, washed down with lukewarm water from a gallon glass jug. Any of you old timers want to add anything …. humfrz |
07-21-2018, 03:06 AM | #22 | ||
Drives: '15 BRZ RA
However, my post above wasn't really about lightweight flywheels, but increasing in general the smoothness of such components. It looks that the tolerance on the balance of them are on the (mass-produced) cars pretty high and Subaru reduced the tolerance for the RA-R components. This means that the engine is revving more smoothly. They posted a graph that shows less vibration and noise, but I have no idea what are the actual gains from this: Google translation says the following: "Balanced BOXER with a high rotational balance, it is easy to go comfortably around the rev limit with an elaborate engine rotation feel, and to keep a higher rotation." As a side note my Toda flywheel & clutch kit was balanced from the vendor. Here is the balancer for this process: I am not sure how Subaru did it for the RA-R. |
07-21-2018, 03:14 AM | #23 | |
07-21-2018, 03:21 AM | #24 | |
There is always a trade off someplace. If unsure what you are giving up then tread softly before changing.
07-21-2018, 06:28 AM | #25 | |
Clutch Suggestions
Dramatic difference in rate at which revs climb and fall with the LW FW. Watch the video closely. Stock is taking about 4 secs to drop from 4K back to idle. The LW one takes about two for drop from 4K to idle. So much hatred around here for LW FWs. I’ve had them on all my cars and never found them difficult on a daily driver. I’ve read similar complaints on most car forums. Some times I wonder if the people saying they’ve had them and didn’t like them actually even had them. I will also add the it has little to do with improving acceleration. It doesn’t need to be the last item to mod for that’s last little bit. It’s more about shifting and rev matching than accelerating. Last edited by ermax; 07-21-2018 at 08:01 AM. |
07-21-2018, 02:02 PM | #26 |
義理チョコ
I get that "so much hatred" is a popular phrase but it really doesn't apply here. Yes, it's a fun feels mod but there are down sides. We've mentioned them. I like having a nice stock 650 RPM idle. I like being able to toss my keys to anyone without having to conduct a pre-drive briefing.
A LWFW is quite a commitment. In the last few years since joining this forum I've been surprised to learn that most enthusiasts do not do their own heavy work. You and I are in the minority. I feel we have a responsibility to discuss these issues openly. That's all.
The Following User Says Thank You to Ultramaroon For This Useful Post: | nikitopo (07-21-2018) |
07-21-2018, 03:55 PM | #27 |
Drives: 2015 Subaru BRZ Series.blue
In my personal experience so far, the flywheel isn't bad at all. I felt like it helped the car a lot. The only downside for me so far is the chatter.
That video was to compare the rpm drop in relation to stock. Night and day difference. Could have been a better video. I was on oft back then so the Rev limiter was set and stuck. It would have been better with ecutek since I can still Rev to full. I didnt personally turn the heater on (I've tried in the brz but pointless and ya that ac is too good here where it's 100-110 all summer), but my dad has when I was a kid. I knew the trick at least. I've had the clutch for a good 10 miles maybe and turbo for a couple thousand, so far the car is still behaving normal. Hopefully it continues to do so. In cabin sounds if anyone cares to hear it, be warned the camera isn't great. Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
The Following User Says Thank You to Strife26 For This Useful Post: | humfrz (07-21-2018) |
07-21-2018, 04:11 PM | #28 | |
* how do you stand that air freshener thing flipping around? * you need a shave * you are too old to be wearing a muscle shirt humfrz - jest ah messen wich ya Actually, your setup is quieter than I would have thought |
Similar Threads | ||||
Need clutch suggestions for daily driving a Turbo FRS | CamFrs | Engine, Exhaust, Transmission | 8 | 04-04-2017 06:27 PM |
First Post Please be gentle. Might need New clutch, suggestions plz? | jsalaz03 | Issues | Warranty | Recalls / TSB | 27 | 11-16-2015 05:33 PM |
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
