Old 01-11-2019, 10:35 AM   #71
Route
Route's Avatar
Drives: 2007 GT3 | 22' BRZ
BRZ tS upper arm rests and cluster visor just came in at work. Only a few things left to do the interior and I'll be done.
Was really bored at work so I also updated my build thread to have every single part number I could find to make it easier for people to source
Route is offline   Reply With Quote
The Following 4 Users Say Thank You to Route For This Useful Post:
MCTeeJ (01-30-2019), Rakshaa (01-14-2019), shadow_772 (01-30-2019), Suparu (06-13-2020)
Old 01-28-2019, 09:27 PM   #72
Route
Route's Avatar
Picked up a Nardi sport rally deep corn 330mm with perforated leather, EVS Tuning carbon steering control adapter, some Rays plate frames, and my Bride interior boots came in.
Finished the installing the shifter boot and will probably install the e-brake boot sometime later this week.
I really hate leather interior trims and try to avoid it as much as possible when it comes to cars so that's why I went with the Bride material for the interior. Pretty ricey but I'm Asian so it's ok.
The Following 3 Users Say Thank You to Route For This Useful Post:
aimforapex (01-28-2019), MCTeeJ (01-30-2019), new2subaru (02-05-2019)
Old 01-30-2019, 12:51 AM   #73
Route
Route's Avatar
Another late night working on the car. I suck when it comes to working on my own car so the installs take me 3x longer than it should.
Bride shift boot has been applied, arm rests attached, cluster hood thing installed and frameless mirror put on.
The Following 2 Users Say Thank You to Route For This Useful Post:
DaSilva3525 (02-05-2019), Suparu (06-13-2020)
Old 02-05-2019, 03:31 PM   #74
DaSilva3525
Drives: 2013 Brz
I always enjoy re going through this thread. If you don't mind answering, I seen you got the Subaru under panels. Did you order them locally in Canada or straight from Japan?
Curious if you still had the part numbers for the panels them selves and all the hard ware. I would appreciate any help, would save major on shipping if I can get them locally
DaSilva3525 is offline   Reply With Quote
The Following User Says Thank You to DaSilva3525 For This Useful Post:
Route (02-05-2019)
Old 02-06-2019, 12:11 AM   #75
Route
Route's Avatar
Thanks! I'm excited to see how everything will look and perform this summer.
As for the parts here are the part numbers that you can use through Canadian Subaru dealers:
Panels
56411CA000
56411CA010
42045CA020
42045CA030
Hardware
901000344 x8
909140065 x16
909140007 x4
023508000 x4
Always safe to buy some extra hardware just incase my number was wrong.
andrew4554 (04-19-2020), DaSilva3525 (02-06-2019), new2subaru (02-06-2019)
Old 02-06-2019, 09:22 AM   #76
DaSilva3525
Drives: 2013 Brz
Panels
56411CA000
56411CA010
42045CA020
42045CA030
Hardware
901000344 x8
909140065 x16
909140007 x4
023508000 x4
Thank you so much brother!
Old 02-11-2019, 09:28 AM   #77
Route
Route's Avatar
TRD Edition dash panel finally came in. Need more suede pieces for the interior to finish everything.
MCTeeJ (02-12-2019), new2subaru (02-24-2019), Vic4uf (04-09-2019)
Old 02-11-2019, 11:29 AM   #78
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
Get better headlights, scrub!
spicyricecake is offline   Reply With Quote
The Following User Says Thank You to spicyricecake For This Useful Post:
Route (02-11-2019)
Old 02-11-2019, 03:41 PM   #79
Route
Route's Avatar
Woahhhhhh I'm getting there LOL
Once the weather gets above freezing I'll install the new ones!
Old 02-22-2019, 01:22 AM   #80
Route
Route's Avatar
Installed some on the interior pieces and it looks ok so far but hard to tell without sunlight. Added an old HKS and Koyorad reservoir cozies because they are just laying around in my room.
Old 02-24-2019, 12:32 AM   #81
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Edit: Just changed out the 4th brake light bulb to an LED. Colour looks similar to what my tail lights are but I have lost the brake light function and it's basically just a fog light now. Looking into buying a dual function LED make it a brake light again
Question: What size LED did you use (or end up using) for your nsidius kit?
btw, Great build so far! Can't wait to see the updated mods this season.
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
Old 02-24-2019, 11:00 AM   #82
Route
Route's Avatar
Thanks! I used a 921 if I recall correctly.
Old 02-24-2019, 09:02 PM   #83
Route
Route's Avatar
I lied it wasn't that size. It's definitely a larger size. Once you get the Nsidius brake light I think I found the size on the bulb itself.
Old 02-26-2019, 06:21 PM   #84
Route
Route's Avatar
A few parts arrived in the mail today. TRD rear aero stabilizer, key case for the Corolla, TRD bolts and TRD shoulder pads.
Also installed the door cards to complete the interior for now. Blacked out the speaker rings to match the rest of the interior.
aimforapex (02-26-2019), HaXx (02-26-2019)
14r, brz, frs, trd, voltex
My Asphalt FRS Build ZaneRL9 Member's Car Journals 14 06-13-2015 03:38 PM
hattrickey's Asphalt Build hattrickey Member's Car Journals 4 08-16-2014 12:00 PM
asphalt.frs.22's Evil fr-s build asphalt.frs.22 Member's Car Journals 1 05-30-2014 07:21 PM
Opposed Asphalt build Opposed Member's Car Journals 30 01-15-2014 11:03 PM
New FRS Asphalt build. Erik-Frs Member's Car Journals 24 09-18-2013 08:18 PM
