Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-16-2018, 08:46 AM | #29 |
Because compromise ®
Drives: Red Herring
The best thing about a Braille is you can feel it in the dark.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post: | Irace86.2.0 (08-16-2018), sato (01-13-2022) |
12-10-2018, 07:26 PM | #30 | |
Drives: 2017 PP BRZ
12-10-2018, 10:42 PM | #31 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
12-11-2018, 11:04 PM | #32 |
Drives: 2013 Scion FR-S 10 Series
None - it’s been great and can go two weeks without being on a battery tender and still start the car. It’s not the lightest solution, but it’s significantly lighter than OEM and still very practical for a daily driver in the real world. I’m very happy with the battery and mounting solution.
12-12-2018, 12:43 PM | #33 |
Drives: 2017 Toyota 86
Which Shorai in particular?
12-12-2018, 01:21 PM | #34 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Since this came back up, I'll add my 2 cents.
My only experience with light weight batteries is with my Lotus. I installed a Braille AGM. The car has an alarm. If I don't drive for 4 or 5 days it is dead. Hooking it to the tinder is just part of the daily routine now. |
12-12-2018, 02:22 PM | #35 |
Drives: BRZ 2018
I thought this Shorai: https://www.shoraidirect.com/en/p130...ty-case-type-3
could withstand our not so cold winters with less than 10-20 days per year below zero temps but from what I read here I should review my decision... |
12-12-2018, 02:49 PM | #36 | |
Drives: 2017 PP BRZ
The Following User Says Thank You to scion fr-s For This Useful Post: | RJasonKlein (12-15-2018) |
12-12-2018, 03:02 PM | #37 |
Drives: BRZ 2018
Found this article about how Li-Iron batteries work on cold climates, they work fine up to 0F/-17C degrees just need different crank process from lead acid batteries at low temperatures:
https://www.batterystuff.com/kb/arti...rformance.html |
12-12-2018, 06:43 PM | #38 |
Drives: 2017 toyota 86
I decided to go with the largest shorai battery, with my custom tray that secures the battery way more then oem does. it’s 5lbs 15oz. Car is garage kept and winter just started. Havnt used a tender yet. Last week it got down to 26F with ice on ground. Car cranked up better then oem used to and after sitting for 48hours over the weekend. Havnt let it sit more then 2days though. After winters over I’ll have a better personal review of a shorai for year round DD.
12-12-2018, 06:54 PM | #39 |
Drives: '13 FRS - STX
Over 1 year on Odyssey PC680, no issue, mostly DD, very mild climate, no issue over a long weekend of no-use but I don't think I've left it for a week or more yet. Will know next spring probably. My commute is usually 15-30 minutes.
Not bad for a ~$120 battery that is two day delivery from Amazon and worth ~10 lbs of weight savings, OE battery is $200+ iirc. |
The Following User Says Thank You to strat61caster For This Useful Post: | nikitopo (12-13-2018) |
12-13-2018, 07:22 AM | #40 |
Drives: '15 BRZ RA
A 10lbs weight savings is within the range of feasible without too many sacrifices.
12-13-2018, 10:05 AM | #41 |
Drives: LS Swapped Scion FRS = 440HP
I have a Deka ETX20L (same as Braille B2015) Customized the factory battery tray and bent up piece of aluminum for a hold-down.
Battery goes dead if the car isnt driven in a week or so. Could be something with my engine swap, or my dash cam. Been focused on other things at the moment so I haven't started probing with a multimeter yet. |
12-13-2018, 10:16 AM | #42 | |
Drives: BRZ 2018
As for weight savings at 5-10Lbs for a LiFePO4 battery there is no comparison, I think weight shouldn't be first decision factor when you are at less than 50% of the OEM 30Lbs battery! |
Tags |
batteries, braille, deka, lightweight battery, shorai |
Similar Threads | ||||
Best lightweight battery still useful for DD'ing? | Keenercarguy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 80 | 06-14-2022 08:35 AM |
Lightweight Battery Tray | smg1138 | Tracking / Autocross / HPDE / Drifting | 9 | 05-02-2018 09:24 AM |
FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 12:07 AM |
MAW lightweight battery kit. | Turn in Concepts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 08-24-2016 06:57 PM |
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
