01-29-2016, 10:37 PM | #533 |
Drives: White 2014 BRZ
So back from the track on ~e65 and ran 13.8 @ 101.
JDL Turbo kit - Ecutek, HRI tuned.
The Following 4 Users Say Thank You to stevo585 For This Useful Post: |
01-29-2016, 11:07 PM | #534 |
Pics or it didnt happen...so pics . Was about 50 F and also about 40% humidity.
02-03-2016, 10:08 PM | #535 |
So I assume no one uses LiPo batteries? Any reason why you can't?
Only thing I can think of is maybe recharging. Its also hard to find the right voltage.What is the under and over voltage of the controller? You could do (4) 7.2V packs. Thats 28.8 V.
02-03-2016, 10:10 PM | #536 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Phantom FTS Electric Supercharger Owners Thread
Need a lipo charger for lipo batteries. The controller isn't setup for it. Plus lipo is much more sensitive to heat. And our engine bay gets fricking hot. Is it possible? Yeah. Will it do better performance? Probably because it makes a huge difference for my rc cars and planes. Is it best for our setup? Eh. Between cost and performance increase probably not. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
02-03-2016, 10:35 PM | #537 |
Yeah I figured charging was the issue.
I might do a dual dump setup (4X) after a while with car audio batteries. There pretty narrow I maybe able to fit them plus the start all in front be about 15 inches. Not wanting to relocate the starter outside the engine bay. I just want that voltage to stay more stable. Its drops to 21-22V that means there isnt enough capacity.
02-04-2016, 08:03 AM | #538 |
Drives: FR-S,GTI
LiPo's are way too expensive. LiOn's would be the way to go. The only advantage lithium polymer has over lithium ion is weight. That's why they are used in RC airplanes and helicopters. A large enough LiPo to use with the ESC would probably cost a thousand dollars or more.
The Following User Says Thank You to WNDSRFR For This Useful Post: | Sojhinn (02-04-2016) |
02-04-2016, 08:04 AM | #539 |
Drives: FR-S,GTI
How about NiCad?
02-04-2016, 07:38 PM | #540 | |
Might be ok with just 10ah still ~30 seconds of boost. The amp dump is way, way faster too at 30C on average. I bet the voltage would not drop much. If the boost level would go up or not is a different story...
02-04-2016, 07:42 PM | #541 |
Those are alot cheaper but don't dump enough amps it seems. Most are like 6C. So you would need ~40 ah. (40 x 6) = 240 amps for 4000watts.
02-05-2016, 07:56 AM | #542 |
Drives: FR-S,GTI
The other thing about LIPO's is their tendency to burst into flame. With the constant charging and discharging they're almost guaranteed to burn your car down. Just look at the "hoverboards".
02-05-2016, 08:54 AM | #543 | |
Our cars would be inspired by Ferraris! Sent from my iPhone using Tapatalk
02-08-2016, 08:06 PM | #544 |
Drives: 2013 FRS
joined the club
Officially a member of the club now. Hope to get it installed this weekend.
The Following User Says Thank You to rdub-S For This Useful Post: | Sojhinn (02-08-2016) |
02-08-2016, 08:07 PM | #545 | |
Let me know if you need help with anything. Sent from my iPhone using Tapatalk
The Following User Says Thank You to Sojhinn For This Useful Post: | FingR-S (02-09-2016) |
02-11-2016, 09:02 PM | #546 |
Anyone set full activation at 50% throttle? Not sure what issues this would cause..I'm sure you could tune it right.
Similar Threads | ||||
Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4306 | 04-18-2024 06:23 PM |
Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6004 | 03-19-2024 02:16 PM |
Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11295 | 02-19-2024 03:42 PM |
phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
