04-11-2012, 11:26 AM | #71 | |
Drives: 2012 WRX Sedan
I've never tuned a car, just installed parts, but just being on Honda forums for 15+ years you can assume that you're not getting 25hp with just an intake on engines like these. The good thing with I/H/E is that those *can* be compatible with S/C setups so its not a total waste, if from that point you want to go all NA, or S/C. Plus in addition to the curve, a lot of NA boxer engines have that very pronounced dip there, even in Porsches, even my Civic SI '02 has it (albeit a smaller one) and I'm guessing things like VTEC were made to remove that dip, or put it higher in the rev range. I'll probably should ask questions like this in the engine thread. Anyway, I don't want an overly loud car, so at most I'd do I/H + Tune and maybe a midpipe (or conservative exhaust, like the TRD), if just for the weight loss. |
04-11-2012, 11:36 AM | #72 |
Drives: TBD
04-11-2012, 11:53 AM | #73 | |
You know you want it.
Drives: '13 FR-S
IL Si: 15.1 @ 93.8 86: 15.3 @ 92.1 MT Si: 14.9 @ 94.7 86: 14.9 @ 95.5 |
04-11-2012, 12:05 PM | #74 |
Drives: TBD
^ Obviously differences in torque curves and perhaps the less performance-oriented rubber on the FR-S come into play here as well.
No test on C&D yet, what are they doing over there?? |
04-11-2012, 12:19 PM | #75 | |
Drives: BRZ!
Very happy with that Dyno... I just wanted to see something similar/better than my previous IS300...
is300: 167.1 rwhp/165.2 lb-ft + 540 pounds
04-11-2012, 12:48 PM | #76 | |
Drives: N/A
04-11-2012, 01:00 PM | #77 | |
Habitual Line Crosser.
Drives: ^ Two of my favorite things.
Trust me, having driven the car, it has more than enough ass to have fun. Also notice the hp curve, this engine was made for fun because you have to work it to get the most from it. When you work a car, you bond with it, and the more you bond with it - the better you get to know it - the better driver you become. Learning to be confident in what the car can do is fun! The more confident in the car you are => the more fun you have. The more fun you have => the faster you can go. Rinse and repeat. Besides a = (F/m). You don't need a lot of 'F' when you minimize 'm.'
But, but, but... It's only 200 hp?!
04-11-2012, 01:11 PM | #78 | |
Drives: '12 C63 P31, '23 GRC
Sorry that's not how it works. This engine was designed for 91 octane so it will make it's advertised horsepower with that fuel. Perhaps it "could" make more on 93 octane, but only if it is tuned specifically for it. And it's not.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
04-11-2012, 01:16 PM | #79 |
Drives: '13 FR-S
04-11-2012, 01:19 PM | #80 |
ZC6A2B82KC7J
Drives: 2002 WRX
Nope, the ECU will make more power on higher octane fuel. It pulls ignition timing until it detects knock and then steps it back. On higher octane fuel you can have more timing advance without knocking. The ECU is optimized for a specific octane but it will still make more power on higher octane, or less power on lower octane. I think it is actually optimized for 93 octane anyways, I believe that's what's listed on the gas door. It probably is not a huge difference between 91 and 93, maybe 5hp.
The Following 2 Users Say Thank You to Spaceywilly For This Useful Post: | Ryephile (04-11-2012), WolfpackS2k (04-12-2012) |
04-11-2012, 02:47 PM | #81 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
Well, anyway, I'd like to next see a dyno of the AT to compare and contrast.
04-11-2012, 03:09 PM | #82 |
Drives: Mazdaspeed 3
04-11-2012, 04:30 PM | #83 | |
Drives: '06 AM V8V Coupe
Because the cam appears to be a high rpm cam, there are no variable intakes, the torque down low approximately matches the torque peak, and the peak torque is quite low by performance engine standards, I think the most logical conclusion is that they intentionally tuned the intake for low rpm. This gives the car "better driveability" (as if you're actually going to floor it while getting groceries :P), and the kick of torque that people like to feel at low speed. I haven't really thought or read in detail on how intake harmonics work though, so I may be missing something important. |
04-11-2012, 05:13 PM | #84 | ||
Drives: N/A
Okay, I was just checking since you didn't mention K20 or the last gen Civic.
The Following User Says Thank You to Allch Chcar For This Useful Post: | WolfpackS2k (04-12-2012) |
Similar Threads | ||||
Cobb Tuning dyno pull | Tainen | BRZ First-Gen (2012+) -- General Topics | 87 | 08-01-2012 06:54 PM |
insideline brz sti rendering | DIG1992 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 16 | 04-02-2012 05:05 PM |
Any publication strap this car on a dyno yet? | mspeed6 | Engine, Exhaust, Transmission | 69 | 02-02-2012 04:48 PM |
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline | rmagic | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 12-15-2011 05:36 PM |
