Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Old 07-04-2018, 01:56 PM   #15
Bonburner
Bonburner's Avatar
Drives: M/T Argento FRS
Originally Posted by jayliu.jiayu@gamil.com View Post
Yea after 10k my coolant is below half now
This is because the coolant rubber line that comes in from above is not air tight seal. A lot of coolant evaporates out of the overfill tank.
I met a fellow at a car meet that showed me to wrap some black electric tape around the hose and jam it down into the overfill tank to make it "air tight". I don't have to refill my coolant as much anymore.
6/22/12 #040XY
Air Filter - aFe Magnum FLOW Pro 5R
Headunit - Seicane S16003
Deka Intimidator 35
Old 07-05-2018, 05:31 AM   #16
jayliu.jiayu@gamil.com's Avatar
Drives: 2017 86 2016 frs 2007 335i
that was really helpful
will keep my eye on it , if i will refill that again i will do it
thx buddy!!!!!
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 09-05-2018, 12:57 AM   #17
that line is easily pull out by my hand after last trackday
saw some white spot in my engine bay
any better solution to fix it ?
a glue gun?
or a proper rub plug ?
Old 09-05-2018, 12:59 AM   #18
here is the video for me last track day after all the part on
big improves
my next move is going to be a racing seat cause the oem seat can hold my well for now
Old 09-05-2018, 02:09 AM   #19
Bonburner
Bonburner's Avatar
a glue gun?
The line shouldn't be difficult .. it's just to reduce the coolant evaporation by reducing the excess gap. I'm able to split mine out with some simple fidgeting.
I'm not sure what you mean by white spot.
I would not recommend a glue gun.
If you want to be fancy you can get a rubber grommet .. find the right diameter and fit it in there ..
6/22/12 #040XY
Deka Intimidator 35
Old 09-05-2018, 03:32 AM   #20
any idea for find a rubber to do it ?
Old 09-05-2018, 03:37 AM   #21
Bonburner
Bonburner's Avatar
just measure the diameter of the tube and buy a rubber grommet at whatever hardware store of your choice
6/22/12 #040XY
Deka Intimidator 35
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
