03-06-2017, 10:49 AM | #7841 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Otherwise if you don't have enough cash for a backup plan, FI is probalby not something you should be pursuing. While these cars are by far the best bang for the buck when you add FI to them, there is always a greater risk of engine failure with boost. |
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post: |
03-06-2017, 08:04 PM | #7842 |
Drives: Sprintex carbon fiber wide body
03-06-2017, 08:09 PM | #7843 | |
Sent from my Pixel XL using Tapatalk |
03-07-2017, 12:25 AM | #7844 |
Grip>Slip
03-07-2017, 05:21 PM | #7845 |
Drives: pinto power
folks with intercooler, would you say the extra install and possible pump hassles are worth it for just going from a 75 to 72.5 mm pulley? looks like on 92 pump gas i might get 20 extra hp with the IC..
edits: daily driver, no track, mildly aggressive driving |
03-07-2017, 05:33 PM | #7846 | |
Drives: 2013 Scion FRS
Running 69mm aggressive tune no IC no probs. Same driving style, daily ambients in the 90s. Although to be fair I'm not in full boost unless it's under 83.
ScreamingElectron - SnakeShit |
The Following User Says Thank You to riboyster For This Useful Post: | camelflage (03-08-2017) |
03-07-2017, 08:24 PM | #7847 |
Grip>Slip
03-08-2017, 05:10 PM | #7848 |
Right foot and butt dyno!
The Following User Says Thank You to riboyster For This Useful Post: | xjohnx (03-09-2017) |
03-12-2017, 03:01 PM | #7849 |
Drives: 2013 Subaru BRZ Limited (Black)
Just as an update for all -- Running Moto-East flex fuel kit now -- Everything working perfectly on E77. Running stock injectors, with 10% fuel headroom on the 72.5mm pulley at 7300rpm (Mike took a look at my logs to confirm how much headroom was available).
I don't track the car or spend much time at 7300RPM, so i'm going to wager that i'm OK for daily-driving use. I'd be much under 90% fuel/injector duty cycle in normal RPM ranges. E85 feels great! The entire RPM range (especially under 4k) is much smoother on E85, whether accelerating aggressively or gently. Plenty more power all around. |
03-12-2017, 04:21 PM | #7850 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
03-12-2017, 04:25 PM | #7851 |
Yes. Stock fuel pump as well.
Not a hickup from anything -- I suspect that the quotes I've seen from others ('E85 burns much cooler than pump gas') are very true. After hard runs I don't have any strange smells coming from the car (was smelling slight burning of fluids/SC/cat or something on 93) and temps are down considerably in comparison to 93. When the ODBII cable gets in I'll do some runs on both E85 and 93 to see what the temp differences look like for coolant and oil between the two fuels. |
The Following 2 Users Say Thank You to ajcarson11 For This Useful Post: | CarzCarzCarz (03-13-2017), stockysnail (03-12-2017) |
03-13-2017, 06:08 AM | #7852 |
Drives: SC BRZ
Anyone running a 210 with stock headers/FP and e85 know what they're dynoing at? e85 blew my clutch and didn't think that happened until 200+ftlbs and 300+hp
also getting a rough start as of late, have to flood with gas to get it to turn over, then runs fine. was on limp mode for a while- plugged cat? |
03-13-2017, 11:10 AM | #7853 | |
I do know of others running the 210 on stock headers though - so I can't imagine it is a huge problem. There have been other boosted folks who have melted the cat in the header through while FI (although that is usually only a problem with high-flow cats). I'm doing OK on stock clutch thus far (and my clutch has 40k of wear). How many miles have you been running E85 on the 210, and how long did clutch last? EDIT: Also been wondering if the burning smell could be brakes. I'm obviously on the brakes much harder when going more quickly. That's a question for another thread though... |
03-13-2017, 11:38 AM | #7854 | |
Drives: SC BRZ
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
