Old 08-19-2016, 11:46 PM   #71
Ultramaroon
義理チョコ
Ultramaroon's Avatar
Originally Posted by jamesw1301 View Post
Has anyone who's removed their sound generator and kept it off for long periods of time experienced any issues?
Originally Posted by B-R-Z View Post
I've had mine off since posting this diy and have no issues. Running strong at 83k
Good to hear! what did you use to plug your intake?
What do you mean? Everything I used is in this diy.
Astroboy (07-27-2017), chaoskaze (08-23-2016)
Old 08-23-2016, 12:04 AM   #72
jamesw1301
Drives: 2013 Subaru BRZ
Sorry, I should have payed more attention. I am now realizing all the parts used are listed in your first post.
jamesw1301 is offline   Reply With Quote
Old 03-11-2017, 08:56 PM   #73
scottbrz
Drives: 2017 BRZ Limited PP
I had tried running with the sound hole plugged (via the power outlet plug) recently and I liked how the car sounded. It seemed like it had a more balanced sound without the intake tube dominating. You could hear the engine, and what little exhaust sound the car has.
I decided to remove the sound generator apparatus and plug the hole left behind in the intake elbow.
I used a 1 & 1/2 inch pvc pipe cap to do so. I purchased it from Home Depot for around $1.
The cap was white, so I had to paint it. The only paint I had on hand was some touch up paint for my mk4 VW, which is a dark grey color. I decided to try it and it looked decent enough for my purposes.
The second challenge I had was that the pvc pipe cap would slip over the intake tube hole and was just about the correct size, but since the pvc plastic is not flexible, it would likely not create a seal even with the worm style hose clamp.
I decided to use permatex gasket maker to resolve this. It works, but it does make this mod more permanent in nature. I just made a bead in the cap, and another on the intake and slipped it on.
Here is a low quality cell phone pic of the final result.
I really like how much it cleans up the passenger side of the engine bay.
scottbrz is offline   Reply With Quote
Old 03-11-2017, 09:32 PM   #74
Ultramaroon
義理チョコ
Lav (05-11-2019)
Old 03-12-2017, 12:17 AM   #75
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Or for even lower tech:
geezerbrzeezer is offline   Reply With Quote
The Following 14 Users Say Thank You to geezerbrzeezer For This Useful Post:
#944_10_Series_FRS (03-12-2017), Andrew025 (03-12-2017), Astroboy (07-27-2017), Code Monkey (01-04-2018), Cole (03-12-2017), Lav (05-11-2019), ncted (05-08-2018), new2subaru (01-08-2018), OrangeGuitar (07-10-2017), Overdrive (01-18-2018), Scrappydoo (03-12-2017), theneptune86 (08-18-2020), Tristor (05-03-2018), Ultramaroon (03-12-2017)
Old 03-12-2017, 12:55 AM   #76
Ultramaroon
義理チョコ
lol
Old 03-12-2017, 01:20 AM   #77
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Better to protect the sausage with a condom. Don't want to contaminate the part...
#944_10_Series_FRS is offline   Reply With Quote
The Following User Says Thank You to #944_10_Series_FRS For This Useful Post:
geezerbrzeezer (03-12-2017)
Old 03-12-2017, 10:35 AM   #78
geezerbrzeezer
Geezer
Sound idea.
And bonus - should your canyon road 'legend in your own mind' hooning ambitions find you obtusely parked in a ravine, pop the hood to enjoy a possibly still warm, condom sterilized, um, 'food' source.
Old 03-24-2017, 04:20 PM   #79
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
I went a bit of a different route than anything else I've seen so far for my total sound generator delete.
I started out with a 1 1/4" PVC Plug from Home Depot. I sanded all of the edges down so that the head was round instead of the ugly octagonal head that's on it for plumbing use. Then I prepared it with a quick acetone wipe down and painted it with Rustoleum black spray paint for plastics.
For the firewall plug, I used bryan767's idea of the SharkBite 3/4" plug
All together I think it worked out quite allright.
EnoOnraefi is offline   Reply With Quote
The Following User Says Thank You to EnoOnraefi For This Useful Post:
Old 04-16-2017, 02:51 PM   #80
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Fixed broken image links since dropbox decided to kill public folder sharing
The Following User Says Thank You to B-R-Z For This Useful Post:
LuckyEinstein (01-04-2018)
Old 01-04-2018, 09:47 PM   #81
LuckyEinstein
Drives: 2013 WRB BRZ
This is a great DIY and the pictures are very helpful! I'm going to give this a shot. Thank you!
LuckyEinstein is offline   Reply With Quote
Old 01-08-2018, 01:17 AM   #82
MyGT86Yas
Drives: 2017 WRB BRZ
NICE DIY. I just removed the noise generator and went for a test drive, LOVING it! The noise that the generator made always confused me, like "why is it so loud when I didn't put that much throttle in". Now it's a lot more clear.
MyGT86Yas is offline   Reply With Quote
Old 02-27-2018, 12:03 AM   #83
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
This still works for MY17. Just did it. Also installed the plex plug from the engine side. worked great. Thanks for the DYI super easy.
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
ncted (05-08-2018)
Old 05-09-2018, 09:13 AM   #84
ncted
I did this yesterday. It really cuts down on the harshness of the noise coming from the engine. Before this, I wasn't sure if I wanted to do any exhaust mods due to excessive noise/not being able to hear the good noise over the bad. This has totally changed my mind.
ncted is offline   Reply With Quote
The Following User Says Thank You to ncted For This Useful Post:
Paiser (09-29-2022)
Search this Thread:
Advanced Search
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 01:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 12:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 04:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
