02-22-2018, 05:45 PM | #1 |
Drives: 2014 Scion FRS (Red)
Forrester Oil cooler
Hey guys,
do you have any recommendations on where to get forrester oil cooler that would fit on the frs? Somewhere that isnt too pricy, in canada? Thanks! |
02-22-2018, 07:05 PM | #2 |
Drives: 13 mt fr-s
From a subaru dealership, really.
As well as it isn't a very effective method of cooling oil. Save a couple more hundred and get a thermostatically controlled sandwich plate and cooler. And if it's the oil warming feature you wanted, take off your exhaust manifold heat shielding. |
The Following User Says Thank You to scottman For This Useful Post: | OrangeGuitar (02-23-2018) |
02-23-2018, 04:35 AM | #3 |
Drives: '17 BRZ Dark Grey Sport-tech 6MT
21317AA070 CONN-OIL COO $48.73
21311AA170 OIL COOLER C $ 186.48 Prices are CDN from a couple of years ago You also need some loose ends as per http://www.ft86club.com/forums/showthread.php?t=73684 Sent from my iPhone using Tapatalk |
02-28-2018, 09:14 AM | #4 | |
02-28-2018, 09:17 AM | #5 |
02-28-2018, 11:31 AM | #6 | |
Get a thermostatic plate if you drive the car year round and you'll be fine.
03-01-2018, 03:42 PM | #7 | |
My car is not boosted. I guess i was looking at the oem setup because it looks fuss free lol! |
03-01-2018, 04:14 PM | #8 |
03-01-2018, 04:37 PM | #9 |
I'm not sure the forester one is less fuss... you don't have to remove the bumper, but do have to install new lines. It took me about two hours, working very slowly, to install my mishimoto cooler.
Included in that time was me poking around to see how easily I could run brake ducts while the bumper was already off.
03-01-2018, 04:53 PM | #10 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
The way I look at it from a holistic point of view and not a detailed step by step, you still need to: 1- Tap into line/reservoir for inlet/outlet 2- Mount new cooler somewhere 3- Bleed and purge air I don't see how a Forrester one would be easier unless it literally bolts on and eliminates the mounting part.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
03-01-2018, 05:04 PM | #11 | |
The forester cooler sits under the oil filter as a sandwich plate (mmm sandwich...). There is nothing to mount in another location. Coolant hoses do have to be run. Oil management remains the same as stock. The install is quick. External oil coolers still have a place. |
The Following User Says Thank You to OrangeGuitar For This Useful Post: | Frost (03-02-2018) |
03-01-2018, 09:24 PM | #12 |
so verdict: oem is fine for mild tracking?
money better spent on aftermarket ones for heavy tracking? |
The Following User Says Thank You to oppiee For This Useful Post: | OrangeGuitar (03-01-2018) |
03-03-2018, 01:56 PM | #13 | |
How often do you plan on tracking the car? How long of sessions do you want to run? External ones still use a sandwich plate, so the oil portion is easy. You don't have to remove the bumper with the OEM one, but you do have to run coolant lines and purge the air from them. I'd bet install time is about the same for both.
03-03-2018, 02:34 PM | #14 |
義理チョコ
The OEM-style is laughable. Nice for stabilizing temps when DDing but that's about it.
Even if cruising at partial throttle with a bone stock engine, a shit ton of heat gets dumped into the bottom end when operated continuously above 4K for any length of time.
Similar Threads | ||||
Forrester XT Style "OEM" Oil Cooler | SpectreRT | Engine, Exhaust, Bolt-Ons | 5 | 09-26-2017 11:35 AM |
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler | TheMedakaBox | Northern California | 4 | 08-09-2017 10:16 PM |
2013 Subaru Forrester | speeddemon | Other Vehicles & General Automotive Discussions | 0 | 01-31-2017 11:16 AM |
Forrester XT cams | FAER | Forced Induction | 7 | 05-14-2014 03:55 PM |
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
