04-28-2016, 12:37 AM | #7099 |
Drives: 2013 Scion FRS
Unless her butt dyno senses 60 more hp...
ScreamingElectron - SnakeShit |
04-28-2016, 12:37 AM | #7100 | |||
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
First off, it's not horsepower that will overwhelm the clutch, it's torque. From experience the stock clutch can give out before 200 lb-ft at the rear wheels. Quote:
--Dan Mach V FastWRX.com |
The Following User Says Thank You to Mach V Dan For This Useful Post: | Keenercarguy (06-14-2017) |
04-28-2016, 01:44 AM | #7101 | |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
As far as the clutch concern, I have yet to see anyone at 200-250tq lose their clutch. Maybe that's just me, but I haven't heard anyone having issues until 300+whp. I know a guy who had his clutch go on a 5th gear pull on the dyno which peaked at 303whp. The run before was 297whp and it held strong. No idea his torque though. I've also used to DD my FRS with 215tq on my stock clutch and had no issues, given every setup is a little different, but if the clutch was only rated for 200tq I would assume I would have heard it.. Given 95% of users who had the issue state it's like 300whp. The heatsoak issue is defiently there, in the intercooled version for sure. I was just making assumptions based on what I know about the system, in regards to the non-intercooled. AIT is going to be the same, regardless, if you're driving. OP mentioned stop and go traffic is where he is at most of the time. And I can tell you myself, on a hot day in July, after driving for a bit, and you go to make that 5th gear pull which is normally quick and painless, you'll have to go to 4th to get the same power from the power loss. You're just putting excess stress on the blower that's hot. My last setup got hot after 4 runs in the dyno with @moto-mike and the system started adding some tip-in knock on the top end.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ Last edited by Rifle; 04-28-2016 at 01:59 AM. |
04-28-2016, 02:42 AM | #7102 | |
04-28-2016, 02:45 AM | #7103 |
I'm pretty sure my NA build was just as fast 0-60 as with hot screws.
The Following User Says Thank You to riboyster For This Useful Post: | Rifle (04-28-2016) |
04-28-2016, 08:02 AM | #7104 | |
Can anyone take a look at this for me?
295WHP/220TQ |
04-28-2016, 11:28 AM | #7105 |
Drives: Toyota 86 with supercharger
This is probably a stupid question, but what happens if you remove the valve just after the plastic air intake? That valve controls the flow of air when there are low RPMs to save fuel? Do you get an increased torque in lower RPM if you could somehow force that open or is it bad to consider such a thing?
04-28-2016, 11:47 AM | #7106 | |
what valve? On the throttle body..? you mean which controls the amount of air you let in relative to your pedal..?
295WHP/220TQ |
04-28-2016, 11:59 AM | #7107 | |
Drives: 2013 SWP BRZ Limited
04-28-2016, 04:14 PM | #7108 | |
04-28-2016, 10:29 PM | #7109 |
Another stranger issue.. My intercooler/heat exchanger assembly.. won't take any fluid... pump spins.. reservoir is filled.. but the lines are empty.....
295WHP/220TQ |
04-28-2016, 11:06 PM | #7110 |
Semi obvious, but did you take the caps off the intercooler input/output lines? If the pump is going then you have to bleed the air. You might have a kink in your hoses too.
The Following User Says Thank You to nmastereal For This Useful Post: | Rifle (04-28-2016) |
04-28-2016, 11:16 PM | #7111 |
Yeah. This is now my second heat exchanger. My FR-S was totaled. Since I've put the system back on my BRZ, I'd had nothing but intercooler issues..
295WHP/220TQ |
04-29-2016, 01:27 AM | #7112 |
Is there any way you can bypass the pump for now? If you could flood the system before getting the pump on, then flood the pump, it'll have something to push and that'll help get the rest of the air out
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
