Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-06-2013, 10:14 AM | #71 |
That guy
Drives: Ultramarine mt FR-S
I thought you were having a custom overpipe made? Contact P&L.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
09-06-2013, 12:20 PM | #72 |
I did now the overpipe hits the head I can line it up fine with the front end off the ground then it seems the outlet on the header is pulled rearward and then rest over pipe on head. I also re adjusted to make sure I had clearance everywhere, then made metal braces that bolted to outlet of over pipe to a trans bolt. still moves and makes contact. I have been under the car 3 times and today will make 4. something to take note is the subframe was not made in mind of having a larger exhaust run around it. Very frustrating. if I cant get adjusted correctly today which I doubt I can my fabricator will re visit what he has done to make adjustments I would like to note to anyone a motiv overpipe to P&L header is completely out of question.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
09-06-2013, 12:58 PM | #73 | |
That guy
Hmm, I could have sworn someone was running the Motiv overpipe and the P&L header with no problems. If you lived closer I would have you swing by so I could take a look at it.
Ultramarine mt FR-S
09-06-2013, 01:06 PM | #74 |
Well I uses the overpipe for the basis of the new overpipe build as soon as I installed it the first time, the stock motiv was pinned very hard ibln every direction
09-06-2013, 01:08 PM | #75 |
That guy
Is the Motiv a wider diameter?
Ultramarine mt FR-S
09-06-2013, 02:17 PM | #76 |
nope its 2.5inch so is my new one.
10-18-2013, 04:34 PM | #77 |
Drives: 95 accord
So, is there a known brand of overpipe that will fit the P&L header w/o rattle besides the stock one?
I have having the same ratlle problem w/ motiv OP in low rpm |
10-18-2013, 05:40 PM | #78 | |
Drives: Subaru BRZ
A big thanks for these review!!! I might think to buy those perrin motormount. With some forced induction, the motor must dance under the hood with stock mount!
Mine goes out today. Hope to get a good one back. |
10-18-2013, 06:45 PM | #79 |
Nice write up, and great pics.
04-24-2021, 12:16 PM | #80 |
Does anyone know the bolt specs for the Perrin engine mount?
04-24-2021, 04:28 PM | #81 |
7/16 - 14 thread and 1" long of anyone needs to know.
Similar Threads | ||||
Nameless Performance Equal Length Stepped Header | Jason@Nameless | Engine, Exhaust, Transmission | 4525 | 11-21-2022 05:38 PM |
P&L Motorsports BRZ / FR-S 4:1 Equal Length Header - Naturally Aspirated | P&L Motorsports | Engine, Exhaust, Bolt-Ons | 244 | 09-24-2015 04:44 PM |
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy | P&L Motorsports | Groupbuys | 634 | 12-03-2013 05:36 PM |
SOLD: P&L Motorsports Equal Length 4-1 Header | yamsta | Engine, Exhaust, Bolt-Ons | 18 | 08-07-2013 10:24 AM |
Borla Releases Equal Length Header, Catless | Huehuecoyotl | Engine, Exhaust, Transmission | 1 | 04-05-2013 09:44 PM |
