Old 05-18-2018, 12:13 PM   #85
gtengr
Drives: 2017 BRZ
Originally Posted by venturaII View Post
Vorshlag states the FA20 and transmission weighs 480lbs.
I agree. Subtract 90 lbs for the trans, 30 lbs for the flywheel and clutch, and I get 360 lbs for the FA20 with no flywheel/clutch/trans.
HASport says...
The HASport weight is too convoluted for me. Adding axles and the trans onto the scales is silly for what most people on the internet are interested in, but I digress. My research suggests the K24A1 weighs 283 lbs (scroll to July 6: http://www.midlana.com/Diaries/Old%2.../2008July-Dec/). Related forum reading suggests that is an accurate number. The 283 lbs weight includes header (no cat), starter, and alternator, but no intake manifold nor flywheel, and no AC compressor. I think adding 5 lbs for an intake and throttle body on the K24 is fair, as well as adding a 10 lbs penalty since the FA20 weight includes a stock catted header, and a more apples-to-apples comparison would allow for a tubular header on the FA20. So, that leaves 283+5+10 = 298 lbs. Add another 15 lbs for the AC compressor and it's 313 lbs vs. 360 lbs with similarly configured engines. The base K24 weight (headers+starter+alternator) would have to be around 230 lbs or less for it to be an easy 100 lbs drop, and I just can't (as much as I want to) find good references for that low of a number.
gtengr is offline   Reply With Quote
Old 05-18-2018, 01:25 PM   #86
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I think you're making it more convoluted than it needs to be, and are ending up adding weights where they shouldn't. The only difference between the published Vorshlag and HASport weights are that halfshafts are included in the K24 weight. Other than that, both numbers include a stock exhaust manifold, and all accessories, including starter and AC compressor, which you seem to be adding back onto the K24 weight for some reason. The only difference really is that you wouldn't be adding the PS pump or axle weight for the Honda back onto the finished product, and that the exhaust manifold and transmissions will be significantly lighter as well. None of this accounts for additional weight loss potential from a lightweight flywheel and/or clutch assembly, either.
At any rate, whether it's 75 pounds or 100 or more, the result of all this would be a much lighter front end, higher redline, more torque and (arguably) a better sounding motor, and that's just if you left the motor otherwise stock...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 05-18-2018, 01:57 PM   #87
gtengr
Drives: 2017 BRZ
I'm making it more convoluted? I don't have to add any weight to the K24 by itself on a scale for it to be obvious that the weight savings is limited to a max ~80 lbs, and that includes disingenuously attributing the weight loss from an AC and cat delete to the K24 engine.
Old 05-18-2018, 05:18 PM   #88
Grawlix
Drives: '14 fr-s \\ 6mt \\ white
Either way, at the end of the day you are putting in an objectively superior engine with well-established aftermarket and a well-documented history of making great power. Even if it didn't shed a pound this swap would be a tempting option.
Grawlix is offline   Reply With Quote
The Following 2 Users Say Thank You to Grawlix For This Useful Post:
Draco_PR23 (05-21-2018), gtengr (05-18-2018)
Old 05-19-2018, 09:50 PM   #89
venturaII
venturaII's Avatar
I never suggested deleting either of those. Perhaps you're thinking of someone else. Or another engine swap and thread entirely.
Old 05-20-2018, 10:17 AM   #90
gtengr
Drives: 2017 BRZ
I never said you did. That was a freestanding hypothetical.
Old 05-31-2018, 05:20 PM   #91
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
This made me sad.... but now the more reason to do the swap!
K Swap Civic vs Supercharged FRS
[ame]https://www.youtube.com/watch?v=VD8BbdV1JLg[/ame]
Alltezza is offline   Reply With Quote
Old 05-31-2018, 06:05 PM   #92
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Very excited about this. Sub'd
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 06-03-2018, 09:05 PM   #93
ZN6k24
Drives: ‘13 frs
Don't you hate it when you're texting and girl and her reply is " k "
Same looking for an a1 to swap. So I can boost it once I have it swapped in and running.
Going for k24a1 cuz low compression and cheap. I know rods are smaller. It’s just that the a2 is a bit spendy and it’s higher compression. And I’m not doing any internal work so I’m not sure what’s better for stock motor turbo build.
Can anyone chime in which one would be a better option for stock internals 450whp? Idk how big of a deal compression is for these blocks. If the compression difference is even worth considering.
ZN6k24 is offline   Reply With Quote
Old 06-04-2018, 02:59 AM   #94
mrg666
pessimistic skeptic
mrg666's Avatar
FRS won the track race without any competition showing how good it is for what it is designed for - track. Civic had a slight edge in the drag race but a Z71 Silverado could have beaten both of them on the drag strip.
I would take the supercharged FRS over that k-swapped Civic any day. We will hopefully see how k-swapped twin will be ...
Old 06-07-2018, 11:19 AM   #95
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Any updates on the progress of the swap?
laextreme5 is offline   Reply With Quote
Old 06-07-2018, 01:31 PM   #96
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Waiting on the mounts to be cut so we can test fit and put them up for sale, waiting on the prototype wiring harness, once I have those 2 things I can roll fast with it.
Pure Automotive is offline   Reply With Quote
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
Alltezza (06-07-2018), Draco_PR23 (06-08-2018), glorydays (06-08-2018), laextreme5 (06-07-2018)
Old 06-07-2018, 04:47 PM   #97
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Great, thanks for the update. Any more info on the second ecu option?
Old 06-07-2018, 08:09 PM   #98
Alltezza
Alltezza's Avatar
Noob question but, if you wanted to turbo or tune your K24 Swap in general. How does the tuning process work as someone that usually does E-Tuning?
Would I need to go through Hondata or KTuner and use their software or would we still be using ECUTEK?
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 10:30 PM
Obnoxious "Blank" banner ad breaking quick reply Clipdat Site Announcements / Questions / Issues 16 03-09-2017 11:44 AM
Stock pistons "rate ore hate" ? Fricke Forced Induction 35 02-25-2016 10:59 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 06:34 PM
My Adventures Aboard "Our Girl" Wes B. Other Vehicles & General Automotive Discussions 3 02-04-2013 11:44 PM
