Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-28-2014, 08:59 AM | #141 |
Yes, I just add the Bilstein B14/B16 option to our website -http://www.raceseng.com/cascam-caster-camber-plates-2012-scion-fr-s-subaru-brz-bundle
They require the same shock nut and spring perch bushing as the OEM shocks. Thanks! |
03-29-2014, 12:06 PM | #142 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Will these work with Bilstein Sport Series shocks/struts and RCE Yellow Springs? What kind of time is needed to get a set of these to Canada?
03-29-2014, 02:41 PM | #143 | |
I believe the RCE yellow springs will fit the OEM spring perch? If so, everything is in stock and can ship the same day. For a shipping estimate, add the products to your cart and the next screen has a shipping quote box. Jarrett Seng Raceseng | Owner 610.336.0206 |
03-31-2014, 05:26 PM | #144 |
Car Nut
Ordered my set today, I can't wait to install everything that I have compiled.
04-01-2014, 09:20 AM | #145 |
i'm sorry, what?
Drives: Canada
question:
i see that with these plates it is possible to shift the top strut outward, but by a much smaller range than inward. Is this due to the limitation of the bodywork or simply the fact that most people don't go the other way. i'm curious how far the strut could be moved out should one need it to.
04-01-2014, 09:57 AM | #146 | |
Most people are not trying to add positive camber. When the car is lowered, you need to add negative camber.
The chance of the positive camber being used all the way is slim to none. I have enough travel built in to get you back to stock camber. Quote:
04-01-2014, 10:08 AM | #147 | |
i'm sorry, what?
Drives: Canada
i'm just curious how much space is theoretically in there.
04-01-2014, 10:31 AM | #148 |
AutoX Nut
Drives: 2022 BRZ
@Raceseng, I thought I saw someone mention that you guys might be working on a 1" rear top hat instead of the 2" one you currently offer. Any idea when a 1" top hat will be available for KW coilovers?
04-01-2014, 10:32 AM | #149 | |
Already available and on the webstore available to buy. I didn't take webstore pictures. Jarrett Seng Raceseng | Owner 610.336.0206 |
The Following User Says Thank You to Raceseng For This Useful Post: | jprice130 (04-01-2014) |
04-01-2014, 10:36 AM | #150 |
AutoX Nut
Drives: 2022 BRZ
Ok great! I went searching before and didn't see the pictures on the website, so I assumed they were still in the works. Thanks!
05-29-2014, 01:26 PM | #151 |
Driving Coach
Mine arrived today!
These are super-ultra-mega-high quality. I am in awe just fondling them. The packaging was also exceptional; best I've ever seen for car parts (Perrin is a close second). Detailed color install instructions and a signed thank you note just make me feel all warm and fuzzy inside about buying them. Thank you @Raceseng! |
05-29-2014, 03:13 PM | #152 |
Drives: 2014 FR-S
how are the NVH levels on the front plates and rear hats? are they similar to stock?
05-29-2014, 04:45 PM | #153 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
05-29-2014, 04:52 PM | #154 |
Drives: 2013 FR-S Ultramarine
@Raceseng
Pm'd and emailed you guys last week on stack height vs stock. Did they come through? Thanks Nathan |
Tags |
billet, billet aluminum, caster adjustment, caster camber plate, raceseng |
Similar Threads | ||||
Tein Flex Z Coilovers | Evasive Motorsports | Brakes, Suspension, Chassis | 54 | 07-16-2017 01:21 AM |
Raceseng | Billet Aluminum Engine Pulleys | Raceseng | Engine, Exhaust, Transmission | 174 | 07-24-2014 12:24 AM |
Raceseng | Lightweight Billet Aluminum Tow Hook | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-27-2013 01:48 PM |
Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
SRP Billet Aluminum Door Sills | pedalpusher | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-20-2012 06:44 PM |
