Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Old 04-06-2018, 01:20 PM   #393
pedroFRS
Drives: 2016 SCION FRS
Anyone running a staggered setup here:
17x8 +45 front
17x9 +45 rear
What tires size are you running and with this setup, do I need any spacers? Will there be an issue with this setup on TRD springs? Just lowered my FRS with TRD springs and plan to put this setup. This is a daily driver setup. TIA
pedroFRS is offline   Reply With Quote
Old 04-08-2018, 06:41 PM   #394
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
17x8 +45 front
17x9 +45 rear
225/45 17
245/40 17
Front will clear. Rear might need a spacer, I'm not 100% sure.
tyler_win_photo is offline   Reply With Quote
Old 04-08-2018, 06:55 PM   #395
pedroFRS
Originally Posted by tyler_win_photo View Post
225/45 17
245/40 17
Thanks...
Old 08-02-2018, 01:37 AM   #396
Hayer_86
Drives: '17 MT 86
Looking to get a set of 17x9 et 35. Ive been debating on whether i should get gold or the white ones. Any suggestions? I have an Ablaze red 86
Hayer_86 is offline   Reply With Quote
Old 08-02-2018, 01:38 AM   #397
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by Wise View Post
I've heard that they don't fit.
The only BBK that I've seen confirmed to fit with the 17x9 +35's is the AP Sprint kit.
How about wilwood? Stoptech?
BRZ RN is offline   Reply With Quote
Old 08-20-2018, 12:43 AM   #398
Hayer_86
Drives: '17 MT 86
17x9 et35
stock suspension
245/40/17 hankook ventus v12
The Following User Says Thank You to Hayer_86 For This Useful Post:
KidRich (08-23-2018)
Old 08-20-2018, 06:41 AM   #399
86MLR
86MLR's Avatar
Drives: 2017 86 limited
17x8+45
Hankook RS4
215/45/17
stock height
Soon to drop 20mm, and original RPF-1 caps are now in the post.
The Following User Says Thank You to 86MLR For This Useful Post:
venturaII (09-25-2018)
Old 09-25-2018, 11:45 AM   #400
wparsons
wparsons's Avatar
17x8 +45 front
17x9 +45 rear
Old post, but don't forget that the spokes are quite different on the 8" vs 9" RPF1's.. looks silly to have both IMO.
flickr
Old 09-25-2018, 12:08 PM   #401
Leonardo
Row Row Row Your Boat!
Drives: 13' FR-S, 07' MDX, 06' Ridgeline,
I agree. Plus, 17x9 +35 with 245/40 will fit with TRD springs and camber bolts. Though you can't max the camber bolts out...
Life is but a Dream!
Old 10-03-2018, 11:55 AM   #402
pinoy_dorifto
Tuloy po kayo!
Drives: 2017 Toyota 86 (A/T)
17x9 +45 w/ 245/40r17 re71r
3mm spacers front and rear
Swift Spec-R wit oem 2017 struts
Spc camber bolts up front on the top to easily adjust max camber without hitting spring seat
Velox Camber plate to finalize camber adjustments
Front camber: -3
Front toe: 0.10 toe out
Rear camber: -2.5
Rear toe: 0.10 toe in
Does not poke out' fits perfect!
2014 toyota Crap Manual 2AR-FE 16V (LEASE RETURNED)
1985 Corolla GT-S Hatch 4AGE 16V (Sold)
1986 Corolla GT-S Hatch 4AGE 16V (Sold)
1991 MR2 N/A T-Top 5SFE 16V (Sold)
1984 Corolla SR5 Hatch 4AGE 20V ST (Sold)
pinoy_dorifto is offline   Reply With Quote
The Following 2 Users Say Thank You to pinoy_dorifto For This Useful Post:
mgarcia707 (03-15-2019), SuperTom (10-06-2018)
Old 10-09-2018, 12:47 PM   #403
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
Enekei RPF1 17x8 w/ 235/45R17
I went with 45 profile instead of 40 because I enjoy the extra "cushion" around town. Cheapest tires ever since this was experimental for me...Injens A1, they were like 60bucks each from WallyWorld! I loose a little bit of cornering ability from the extra sidewall but the extra grip from the tire contact patch helps offset that. If I was going to race on a track I definitely would go a lower profile. It does give it a nice meaty stance though...compared to stock. Rims are a +45 Offset (no spacers used in photos/ Stock ride height)
OFT | Raceng LW Crank Pulley | Borla UEL Catless Header | PL 2.5" Overpipe | Invidia Catless Resonated FP | 3" Perrin Catback | K&N drop-in | Enkei 17x8 rims (235/45 tires) | Velox Carbon Fiber Driveshaft
chazmuska is offline   Reply With Quote
Old 10-10-2018, 02:44 PM   #404
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Front camber: -3
Rear camber: -2.5
17x9 +45 sounds great for the front, Ive seen +35 and its borderline too much poke for me.
I might do 17x9 +45 front
17x9 +35 rear with 245/40/17 all around
It would be a square tire setup but I guess you could call it stagger offset
SuperTom is offline   Reply With Quote
Old 10-10-2018, 04:29 PM   #405
Leonardo
17x9 +45 will fit great with coils, but so will 17x9 +35. If you have any camber at all, it will tuck the top of the tire nicely with +35. I have 18x9 +30 front and only -1.4 camber.
If you get +45 all around and 10mm spacers for the rear, you could rotate your tires. If you get staggered offset, you can't.
Old 10-10-2018, 04:50 PM   #406
SuperTom
SuperTom's Avatar
Good info I have coilovers im at -1.5 front , -2 rear
If I stay 17x9 +35 then I would go with Wedsports. Still deciding but some pics still like borderline too much poke which scares me
Point of doing +45 upfront, +35 rear would be so I don't have to add spacer in rear. Not worried about rotating too much I have light 17x8's and stock tires with winter tires So im always rotating wheel setups. Just looking for a 17x9 set I will call my "grip setup"
The Following User Says Thank You to SuperTom For This Useful Post:
Leonardo (10-10-2018)
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 781 09-26-2018 05:48 PM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question Victor Draken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-19-2013 02:28 PM
Track wheel Enkei RPF1 in 16" ?? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-07-2013 09:13 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
