Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-28-2018, 07:59 PM | #29 |
Coop, a very good, informative, one of your first posts ..
I'll comment on her nice legs, before ol @Clipdat drools all over them. humfrz |
06-28-2018, 09:51 PM | #30 | |
義理チョコ
06-28-2018, 11:31 PM | #31 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Doesn't help that my car stays parked at a valet operated garage all week, so I only see it on the weekends when I actually drive it. I'd be tinkering with that switch right now if I lived in a house with a garage to keep the car in lol. |
The Following User Says Thank You to PandaSPUR For This Useful Post: | Ultramaroon (06-28-2018) |
06-29-2018, 12:55 AM | #32 | |
Drives: 2013 Subaru BRZ
If i'm not mistaken the blue one is the starter safety switch and the black one is the cruise control switch... https://www.rockauto.com/en/catalog/...ol+switch,4320 |
06-29-2018, 10:47 AM | #33 | |
06-29-2018, 08:59 PM | #34 |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | Beachin86 (03-18-2019) |
06-29-2018, 09:04 PM | #35 | |
義理チョコ
06-29-2018, 10:10 PM | #36 |
Hey so I had the same issue and i just fixed it today. My BRZ wouldn't start all the time and I thought it was the safety switch. Well it turns out that I had a big air bubble in my clutch. I bled my clutch and tons of air came out. Now it starts like new, and even driving is so much better!
The Following User Says Thank You to Coop For This Useful Post: | humfrz (06-29-2018) |
06-29-2018, 11:10 PM | #37 | |
06-29-2018, 11:50 PM | #38 |
Because the brake fluid doesn't compress and air does. Pretty much when I pushed my clutch all the way in it would actually not be separating the clutch from the fly wheel all the way, just partially. And I think there is a sensor in the actual clutch that can tell if it is separated or not.
06-30-2018, 10:41 AM | #39 |
I Love custom Turbo kits
Drives: Limited BRZ
With the pushbutton, the switch can't be defeated because it's the only way to get into ACC and ON ignition positions (correct me if I'm wrong).
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Ultramaroon (06-30-2018) |
06-30-2018, 01:39 PM | #40 | |
義理チョコ
Now I'm even happier that I still have a key.
06-30-2018, 01:42 PM | #41 | |
Drives: Limited BRZ
That’s what I think because if you depress the clutch and push, you immediately crank. In order to get to ACC and ON, you need to not depress the pedal (all which is info passed to the ECU via the switch)
06-30-2018, 01:49 PM | #42 | |
義理チョコ
I really don't like that. I guess if I was forced to use that circuit, I'd move the clutch interlock to another position on the dash so I'd have to use both hands to crank. ...maybe.
Similar Threads | ||||
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch | BII302 | Engine, Exhaust, Bolt-Ons | 6 | 04-13-2015 07:06 PM |
Clutch Switch Bypass | OmarGC | Engine, Exhaust, Transmission | 20 | 01-01-2015 09:41 PM |
Swapping out exhaust tips, bolts broke off!!!! Help! | BBYZILA | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 12-19-2014 07:04 PM |
Start Stop Switch - BRZ Limited | whatsinaname | BRZ First-Gen (2012+) -- General Topics | 7 | 05-18-2014 09:30 PM |
Push-button start clutch switch | mike the snake | Engine, Exhaust, Transmission | 8 | 04-14-2014 11:31 PM |
