Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-10-2019, 11:35 AM | #15 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
02-10-2019, 11:48 AM | #16 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
It seems a little unusual that a 2016 would have had it's OEM battery replaced already but that appears to be the case.
1. Is the OP the original owner of the vehicle? Do you know why or when the battery was replaced? None of the "install date" dots on the battery label have been removed. 2. A "Toyota TrueStart" battery was likely installed at a dealership. Can you log in to the the Toyota Owners Website at toyota.com and check for service records relating to the battery? 3. Is there something wrong with the charging system that it is overcharging and destroying batteries? The battery doesn't appear damaged in that way. Is there a pressure relief valve that would blow to the side of the battery? 4. Notice the amount of corrosion under the rear battery clamp. There almost had to be some acid present on the top of this battery (or a previous one) for an extended period of time to have that much corrosion. That didn't happen in just a couple days. 5. Is the battery cap nearest the positive terminal fully seated? It looks a little higher/different than the other one. 6. What does the underside of the hood look like? Is there a spray pattern that would provide further clues to the source? Was there something (other than battery acid) spraying on the hood and running off onto the battery? I agree with Sapphireho and Tcoat: The stuff that is sprayed all over doesn't look or act like battery acid. It appears to be a little thicker than liquid acid and the wrong color. |
The Following User Says Thank You to LimitedSlip For This Useful Post: | gravitylover (02-10-2019) |
02-10-2019, 12:07 PM | #17 | |
02-10-2019, 12:21 PM | #18 | |
Simply Forgotus
The Following User Says Thank You to BirdTRD For This Useful Post: | Tcoat (02-10-2019) |
02-10-2019, 12:39 PM | #19 |
The Following User Says Thank You to humfrz For This Useful Post: | BirdTRD (02-10-2019) |
02-10-2019, 12:44 PM | #20 |
The Following 3 Users Say Thank You to LimitedSlip For This Useful Post: |
02-10-2019, 12:49 PM | #21 |
The only time I have seen that much out of a battery was when someone tried to jump a car and put the cables on the wrong terminals and got scared and left them on and stepped back. I would agree to checking the fluid level first then looking for a cooling leak.
02-10-2019, 03:16 PM | #22 | |
humfrz |
02-10-2019, 04:24 PM | #23 |
I have blown up at least 3 batteries over the years. None looked like that. In fact most ended up with a really clean engine bay from the acid and then baking soda rinse.
The Following User Says Thank You to Tcoat For This Useful Post: | ls1ac (02-10-2019) |
02-10-2019, 06:22 PM | #24 |
義理チョコ
How many more you figure before you get it right?
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (03-30-2019) |
02-10-2019, 06:26 PM | #25 |
None. I have it down pat now.
02-10-2019, 06:29 PM | #26 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (02-10-2019) |
02-10-2019, 08:29 PM | #27 |
Drives: 2017 Subaru BRZ PP WRB
It looks like the pollen mixed with moisture that has recently covered everything outdoors...
03-30-2019, 07:24 PM | #28 |
Simply Forgotus
Tags |
battery |
Similar Threads | ||||
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit | jonesy | Engine, Exhaust, Bolt-Ons | 1 | 08-25-2017 10:46 AM |
Engine Won't Crank - Battery or Worse - Sanity Check | StrangeLove4791 | Issues | Warranty | Recalls / TSB | 16 | 02-22-2017 11:18 PM |
MeisterR ZetaCRD+ Coilovers pictures and contents | MeisterR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 11-10-2016 09:46 AM |
How long does stock battery last without engine on? | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 03-15-2015 09:58 PM |
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
