06-04-2018, 02:51 PM | #799 |
Drives: 2013 FRS
Hey guys I have a V1 and need to do the SC oil change on it. I dont have my manual however and cant find one except for the install manual on the V3 from ft86speedfactory.
It does not offer much help in terms of showing a procedure to doing this oil change safely. -does anyone have a link where I can download the V1 manual or other reference to use? also has anyone done it that can give advice on this? thanks ! |
07-07-2018, 01:35 AM | #800 |
Drives: 2013 GT86
Anyone using an aftermarket intake or induction box with their v2 or v3?
08-01-2018, 11:09 AM | #801 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
So how is everyone's reliability holding up?
08-07-2018, 11:31 AM | #802 |
Drives: '15 BRZ RA
08-12-2018, 05:53 AM | #803 | |
Drives: 2013 GT86
Which spring did you use with ur tial qrj? |
08-13-2018, 03:42 AM | #804 |
Drives: Brz WRB - Europe LHD
Now on test! I install a new wider restrictor of 41 mms of diameter vs the stock one of 39.
Car gains much more reactivity on medium –low range and from initial logs I see a medium range of +20grs air, a need of +6/7 of fuel in comparison with stock configuration of HKS V2. It’s mandatory to revise all parameters first of all DI+PI and to better balance engine load. I think that this is the best mod for upgrade HKS V2 without exceed and no need to change fuel pump and injectors. Tune suite: Ecutek RaceRom10, 100 RON fuel only. * To cut with laser a new Iron Aisi304 restrictor I paid $10,00 (if someone wants I get the file for laser cutting). Inviato dal mio SM-G960F utilizzando Tapatalk
The Following User Says Thank You to Trap63 For This Useful Post: | Yobiwan (08-13-2018) |
08-13-2018, 09:50 AM | #805 | |
Drives: Toyota 86 Turbo, Lexus NX300H
(max boost is about 11.5) I use 45.5mm now with stock injector, pump & STI maf sensor. max boost is about 12~13 depends on IAT & altitude. good luck !
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
The Following User Says Thank You to Yobiwan For This Useful Post: | Trap63 (08-13-2018) |
08-13-2018, 10:03 AM | #806 | |
08-13-2018, 10:27 AM | #807 | |
Here http://www.ft86club.com/forums/showthread.php?t=106496
08-27-2018, 05:04 AM | #808 |
Drives: 2013 Whiteout FRS
Hey guys, I have the v3 kit and love it. Two questions for someone seasoned - any idea why I see -11 vacuum at idle instead of 20ish? This is the reading from my OFT. second, how do I attach a Tial QRJ to the HKS manifold? I'm having a tough time finding the base that fits. I emailed Tial but haven't gotten a response. Thank you!
09-05-2018, 01:02 AM | #809 |
Drives: toyota 86
What headers and front pipe is everyone running?
I’m concerned once the standard headers are removed I will experience a terrible rasp in the exhaust. Does anyone have an ACE header and catted front pipe with the hks supercharger?
09-05-2018, 02:03 AM | #810 | |
very low sound and no resonance. Only very high Db level @160Km on highway Inviato dal mio SM-G960F utilizzando Tapatalk
The Following User Says Thank You to Trap63 For This Useful Post: | johl (09-05-2018) |
09-05-2018, 03:37 AM | #811 | |
Drives: toyota 86
I was hoping it was possible to keep the exhaust a little on the quiet side with no annoying rasp or drone so that is good to hear. Thank you
The Following User Says Thank You to johl For This Useful Post: | Trap63 (09-06-2018) |
09-14-2018, 08:28 PM | #812 |
Drift noob
Drives: 2015 BRZ Sport-Tech CWP 6MT
Differences between HKS supercharger kits
Hello FT86'ers,
I am shopping for my first supercharger and I have been researching the HKS V3 kit which I believe is the 12001-KT003. On the HKS JP website theres also the PRO 12001-AT009 which says its to be discontinued as per the site, and the GT2 PRO 12001-AT012 kit: https://www.rhdjapan.com/hks-gt2-sup...t-zn6-zc6.html Pricing is not too much different between them all and I was just wondering what the main differences are. Also, any reviews or comments regarding the flash editor if I were to get one with it? Thanks in advance for the info.
FT86Z
藤原とうふ店 |
Similar Threads | ||||
Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4306 | 04-18-2024 06:23 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
