RR Racing
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 07-24-2015, 09:53 AM   #141
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
https://youtu.be/Zw3kLUExq2Q
Ryaquinn is offline   Reply With Quote
The Following 2 Users Say Thank You to Ryaquinn For This Useful Post:
Astroboy (07-24-2015), FutureFT86 (10-01-2015)
Old 08-18-2015, 09:52 PM   #142
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
What were u running for alignment when u had stock control arms in front?
2013 ultramarine frs sold
2014 ultramarine frs
sosick is offline   Reply With Quote
Old 08-19-2015, 04:39 PM   #143
Top-Secret
Drives: FRS monogram
whats max angle for PBM super angle kit? i was looking into that WAY back when it was pre-production but completely forgot until i saw your thread
keep up that good work
Top-Secret is offline   Reply With Quote
Old 09-24-2015, 08:00 AM   #144
Zer0
Drives: 2015 frs
I put in the Ohlins coilovers, pbm solid subframe riser bushings, and diff riser bushings. Looking to do the angle kit next. How long did the install take? How do you like it?
Zer0 is offline   Reply With Quote
Old 09-24-2015, 09:33 AM   #145
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Have you considered lightening mods with minor power bumps, like an aluminum driveshaft?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-27-2015, 06:26 PM   #146
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Draco_PR23 (01-19-2016), DustinS (09-28-2015)
Old 09-28-2015, 09:26 AM   #147
JDM Haze
JDM Haze's Avatar
Drives: Whiteout FRS
What's in the box?
JDM Haze is offline   Reply With Quote
Old 09-28-2015, 09:29 AM   #148
RWDfun
RWDfun's Avatar
Drives: 2015 Asphalt FR-S
New engine?
RWDfun is offline   Reply With Quote
Old 09-29-2015, 11:43 PM   #149
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
The Following 9 Users Say Thank You to Ryaquinn For This Useful Post:
2014scionfrs (11-29-2015), DAEMANO (02-02-2016), DavidBob (10-01-2015), Draco_PR23 (01-19-2016), FutureFT86 (10-01-2015), Majik (07-03-2017), R2RO (12-18-2015), shifter907 (01-27-2016), Summerwolf (06-24-2016)
Old 10-01-2015, 10:19 AM   #150
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Ohh crap looks like i read through your thread at the perfect time... Cant wait to see this keep your faith bud if God's in first place in your life then everything else will fall into place
DavidBob is offline   Reply With Quote
The Following 2 Users Say Thank You to DavidBob For This Useful Post:
2014scionfrs (11-29-2015), Ryaquinn (01-07-2016)
Old 01-07-2016, 01:26 PM   #151
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Haven't updated in awhile since I'm still deployed.
Finally got the swap kit enroute this week. Going to try the CX Racing kit: http://www.cxracing.com/mm5/merchant...ry_Code=ESKSUB
The car is getting final preparation before the motor goes in.
More soon.
The Following 4 Users Say Thank You to Ryaquinn For This Useful Post:
2014scionfrs (01-07-2016), DAEMANO (02-02-2016), Draco_PR23 (01-19-2016), sam69 (01-18-2016)
Old 01-23-2016, 02:59 PM   #152
Amir Ghadiri
Amir Ghadiri's Avatar
If you're keeping the factory steering rack, you may want to use the oil pressure port on the side of the motor for feed to your filter. Clearance on the underside of the motor at the rack is less than ideal. The return port is easy to get to though!
Amir Ghadiri is offline   Reply With Quote
Old 01-27-2016, 01:21 PM   #153
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Yup, using stock steering. We are going to run lines for an oil filter relocation to possibly put it up on the firewall.
Old 02-17-2016, 12:14 AM   #154
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
CX Racing LSx kit mounted up
Brian Tooley Racing stage 4 cam kit
Search this Thread:
Advanced Search
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 20 10-29-2013 06:15 AM
Drifting frosty86 Off-Topic Lounge 8 11-14-2012 10:04 PM
Drifting? frosty86 Scion FR-S / Toyota 86 GT86 General Forum 23 10-11-2012 01:13 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
FT-86 II (RC) Drifting ft86cbx Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 03:02 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
