Old 10-19-2014, 09:30 AM   #253
ofuts
Drives: 2013 Toyota 86 MT
Hi guys
I want to fit some 18*9,5 concave wheels (didnt decide yet, might even go with 18*9 if possible becouse i dont like the poke) and 255/40/18 AD08s at all corners, so i need coilovers.
This is my daily car, i will go to track from time to time but just for fun, not going to push the car too much. I feel ride hardness is just fine with stock suspension and with stock 205/55/16 tires, roads here are not so good btw.
I am planning to lower the car about 1". I have a limited budget i am not a pro, so which coilover would you recommend for a comfortable ride similar to stock? I have a limited budget can not afford top quality.
ofuts is offline   Reply With Quote
The Following User Says Thank You to ofuts For This Useful Post:
10series_frs (03-02-2015)
Old 10-19-2014, 09:34 AM   #254
ofuts
BTW, can all coilovers adjust camber? Or do i need additional parts for some?
Old 10-19-2014, 09:53 AM   #255
jvincent
jvincent's Avatar
When you lower the car the rear camber will increase, i.e. become more negative.
The front will not change. Some coilovers have slotted top holes in the front which allows you to increase the camber.
The Following User Says Thank You to jvincent For This Useful Post:
ofuts (10-20-2014)
Old 10-19-2014, 01:07 PM   #256
ofuts
Lets say Stance coilovers, do they have?
If not, will i need other parts to adjust camber (front and rear)?
Old 10-19-2014, 08:40 PM   #257
jvincent
jvincent's Avatar
Better to ask Stance or whoever is selling them.
As far as other parts it depends on how much camber you want. If the front struts are slotted all you probably need are camber bolts. For the rears if you want to adjust them from what the drop gives you, you will need LCAs.
ofuts (10-20-2014)
Old 12-08-2014, 02:52 PM   #258
ISC Suspension
ISC Suspension's Avatar
Drives: ISC Suspension BRZ
Send a message via AIM to ISC Suspension
Rear camber can be adjusted with aftermarket control arms. We make some, as well as other companies.
ISC Suspension is offline   Reply With Quote
Old 01-21-2015, 07:38 PM   #259
Bomz
Does it drift?
Drives: 2013 Subaru BRZ
No actual answers for my original question. Does anybody know why you would want the front harder than the rear as opposed to the rear being harder as designed by Toyota/Subaru?
Bomz is offline   Reply With Quote
Old 01-21-2015, 08:46 PM   #260
cjd
cjd's Avatar
Drives: 2017 BRZ
It's not quite that straight forward. Effective wheel rate including swaybar is front heavy from the factory - of course the BRZ is different than the FRS with higher stock spring rates up front, lower in the rear. That said, I've read a few threads that suggest for certain types of AutoX you want a higher spring rate up front (heavy on transitions, I think?) - I haven't checked the math to see what that actually works out to as far as wheel rate goes. And I think (my math may not be quite right yet...) that most competition packages still put slightly higher effective rate to the front. Braking, turn-in, ... there's so much in play and I honestly don't understand it properly to really answer; you might need a book or three.
What prompts you to ask?
Old 01-22-2015, 03:00 AM   #261
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
To elaborate on @cjd's post above
I am not 100% certain that these spring rates are correct but you will get the idea.
OEM Scion FR-S
Actual Front Spring Rate 2.3K.... At the wheel 2.1k
Actual Rear Spring Rate 3.8K......At the wheel 2.1k
OEM Subaru BRZ
Actual Front Spring Rate 2.7K..... At the wheel 2.4k
Actual Rear Spring Rate 3.5K.......At the wheel 2.0k
See this article for info about motion ratio http://www.ft86club.com/forums/showthread.php?t=9936
There is no one "correct" front/rear bias. It depends on the intended use of the vehicle and driver preference.
That's because if you want to be competitive, an AutoX setup and a track setup are mutually exclusive.
AutoX priorities:
- lightning fast weight shifts and small direction changes (less than 30 degrees). This is for slaloming.
-- This is achieved by REALLY high front spring rates, and a giant front sway
-- This also makes it so that under sustained cornering (sweepers), the car pushes like CRAZY, so that's why AutoX cars go deep, brake hard, and power out, rather than make a more rounded arc.
Track priorities:
- Sustained cornering speed, and being able to put power down at corner exits
-- This is achieved by getting a nice static balance.
-- Keep in mind that under power, you're unloading the front, and loading the rear.
-- Track prepped cars will sustain more raw cornering Gs, but not change direction and shift weight as quickly.
For example:
AutoX prepped FRS
- 14k/9k spring rates
- Blade type front sway, minimal rear sway
Track prepped FRS
- 10/12k spring rates
- Sways to fine tune balance.
Each car has its strengths and weaknesses. The AutoX car will likely slalom ~20% faster (raw mph), but the track prepped FRS will hold more speed on a skidpad (raw mph).
Old 03-26-2015, 04:12 PM   #262
Hyper4mance2k
Shadetree Project Ratchet
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by WingsofWar View Post
Please post a reply in this topic if you have new information.
I need your help to complete the data in this list!
Swift SpecR ZC6 13+ 4T909R
Front: 4.4 kg/mm, 245 lb/in drop: -28mm, 1.1 in
Rear: 5.3 kg/mm, 296 lb/in drop: -25mm, 1.0 in
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 07-12-2015, 08:48 PM   #263
babyface
Drives: Scion FR S
guys im planning to buy RSR sports i coilovers.. seems adjustable cambers dont come with it.. can i use the OEM camber or do i need to buy theirs?? thanks..
babyface is offline   Reply With Quote
Old 07-14-2015, 02:18 AM   #264
timmydatooth
Drives: Scion Frs
Planning on getting the TRD lowering springs, according to OP these have the least amount of drop compared to other aftermarket springs right? I want something that will give my car a little drop and won't affect my daily driving too much. Would TRD be a good choice? Thanks and if anyone is selling them let me know. aha
timmydatooth is offline   Reply With Quote
Old 07-16-2015, 07:50 PM   #265
solort
Drives: Series 10 FRS
And what are the front and rear spring rates for the TRD replacement springs (PTR07-18130) vs the stock FRS springs?
solort is offline   Reply With Quote
Old 08-10-2015, 11:33 PM   #266
babyface
Drives: Scion FR S
is -3 camber in the rear safe to drive in 70 - 90 mph highways??
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
