Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-15-2013, 08:48 AM | #15 | |
It's the Mad Cow
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
The Following User Says Thank You to Cross For This Useful Post: | pierce88 (11-15-2013) |
11-15-2013, 08:50 AM | #16 | |
It's the Mad Cow
11-17-2013, 08:50 AM | #17 |
Drives: FR-S, 6MT, White
Interesting idea I think it's an Eaton sc and the clutch was made by the same outfit that made them for Toyota in the 80s. It was never intended to be switched manually of course. They had systems to lock the clutch under load. Even a small improvement in fuel economy is important to a manufacturer trying to hit corporate average fuel economy standard.
Do you use a terminal emulator to configure the clutch? (Noticed the cisco rollover cable in the photo) Sent from my SPH-L900 using Tapatalk 2 |
11-17-2013, 10:13 AM | #18 | |
As for the actuating system, it's mainly sudden throttle position change. The old roots blowers would melt the coatings easily if always engaged. This along with economy was the main reason for the clutched setup due to the inefficient of the roots blower and the stupid placement of a tiny intercooler with limited air flow. Not the case with the current offerings of sc kits though. Just because you can doesn't mean it's a good idea such as jumping off the train platform.
11-17-2013, 11:11 AM | #19 |
It's the Mad Cow
I'm at the AZ86 bash now but to put it simply this setup has been proven on the custom kits made for years using this SC on Mazda V6's.
If you don't like the idea that's fine but regardless it's been proven and we'll liked on a bigger motor. So at this point your ties to the 1st gen MR2 from 1986 compared to the 2003 and above Mercedes that this comes from is a little misinformed. Thank you though. On the other question. Because I'm at the bash it's hard to address it but I will tonight when we get back home. Sent from my iPhone using Tapatalk
11-17-2013, 11:53 AM | #20 | |
I was addressing his points, but yeah, misinformed, how so?
11-17-2013, 11:55 AM | #21 |
It's the Mad Cow
The issues with clutch failure on these units from actual use in such applications. But hey let's argue over the internet in a thread you obviously are not interested in for anything other than disapproving
11-17-2013, 11:58 AM | #22 |
I did not say anything about clutch failure. Let's not render this into some petty internet keyboard warrior's playground.
11-17-2013, 12:39 PM | #23 | |
It's the Mad Cow
Clutched Supercharger Build, yes they do exist
Thanks for agreeing to let the thread get back on track. Sent from my iPhone using Tapatalk
The Following User Says Thank You to Cross For This Useful Post: | SirBrass (11-17-2013) |
11-17-2013, 01:08 PM | #24 |
Again, I was addressing his points with more info he wasn't sure of, so how was I misinformed?
11-17-2013, 01:26 PM | #25 | |
It's the Mad Cow
I'm at the bash and I have again asked you to stop you are not interested that's fine and that's where it should end. The same company could very well be involved in making the clutch however as pointed out 1986 vs 2003 and the concept just because you can jump doesn't mean you should vs proven heavy use has been addressed. Thanks Sent from my iPhone using Tapatalk
11-17-2013, 02:20 PM | #26 |
Thupercharged
Is there a difference in crank pulley diameter between the FRS and the car the supercharger came off of?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
11-18-2013, 05:29 AM | #27 | |
Anyway, again, how was I misinformed? What are the differences in the setup between the 1986 toyota SC vs 2003 MB SC other than the charger? What were their reasons for going with the clutched type SC? What are their reasons for not utilising the clutched setup anymore? What are your reasons other than it's different? How is it feasible? What do you mean by easily removed? What do you mean by proven heavy use? I wasn't and never talked about the reliability of the clutched pulley setup. What are you actually proving? |
11-18-2013, 06:36 AM | #28 |
Drives: 4 wheels
I was really hoping innovate's sc would sound like this but it barely makes a sound. So disappointing!
Similar Threads | ||||
Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11295 | 02-19-2024 03:42 PM |
Project Breezy Vortech Supercharger Build!! | 86design | Member's Car Journals | 10 | 09-27-2013 01:33 PM |
FT-86 SpeedFactory Vortech Supercharger Build | FT-86 SpeedFactory | Forced Induction | 91 | 09-26-2013 08:02 AM |
