Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-29-2017, 10:42 AM | #1 |
Drives: Subaru BRZ Limited
hairline fracturing in front brake rotor
I went to swap in my track pads (Winmax W5) last night to get ready for a track day this weekend and found my front rotors looking like this:
https://imgur.com/tTypskf (I'm getting an error trying to attach the image... "Upload failed due to failure writing temporary file.") hundreds of tiny hairline fractures. I don't have a lot of track car maintenance experience but in all my normal vehicle maintenance experience, I'd never seen anything like it. I'm guessing it's from rapid heat expansion and cooling? Both sides of both front rotors look like that. Is it bad? It looks to me like it's about to come apart in a million tiny pieces, hahha. Last edited by JoeC; 09-29-2017 at 11:03 AM. Reason: fixed the image (sort of...) |
09-29-2017, 10:48 AM | #2 |
Drives: 2013 Hot Lava FRS
Picture isn't working, but if i saw cracks in the rotor on my car i would NOT drive it and I would have it replaced immediately. Don't want to have them fail while you're driving and end up killing yourself or someone else.
EDIT: I guess picture link was added. Doesn't look bad Last edited by Slammillionaire; 09-29-2017 at 12:31 PM. |
09-29-2017, 10:55 AM | #3 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Sounds like time for new rotors.
Now that I can see the pic, your fine. Last edited by Sapphireho; 09-29-2017 at 11:31 AM. |
09-29-2017, 10:57 AM | #4 |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
09-29-2017, 11:16 AM | #5 | |
09-29-2017, 11:16 AM | #6 |
Drives: 15 BRZ LTD, 05 FXT
Replace your rotors. Centric blanks are my preference for 95% of applications on these cars.
The Following User Says Thank You to JazzleSAURUS For This Useful Post: | JoeC (09-29-2017) |
09-29-2017, 11:20 AM | #7 |
Drives: Subaru BRZ
That's normal, nothing to worry about.
The Following User Says Thank You to Code Monkey For This Useful Post: | JoeC (09-29-2017) |
09-29-2017, 11:24 AM | #8 |
The Gunshine State
Drives: '14 BRZ Limited
It's just surface crazing and will wear down smoothly over time and use.
Current DD: M235i |
The Following 2 Users Say Thank You to 8RZ For This Useful Post: | JoeC (09-29-2017), strat61caster (09-29-2017) |
09-29-2017, 11:25 AM | #9 | |
http://www.autoanything.com/brakes/6...RoCcB8QAvD_BwE |
09-29-2017, 11:32 AM | #10 | |
As it says your pads are not removing the heat efficiently leaving the scary looking but totally harmless marks. At work (we make rotors) we get attempted warranty claims for this all the time. It is a total non issue.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
09-29-2017, 11:32 AM | #11 |
I did. And it is. I'd run them. But there's no accounting for not feeling confident in your gear, so if that's the case, replace them. But you're likely going to get the same results.
09-29-2017, 12:27 PM | #12 |
Are these stock rotors? How many miles? How many track days?
09-29-2017, 12:42 PM | #13 |
Drives: '13 FRS - STX
Thickness is more important than how the surface looks when it comes to deciding whether or not to replace them. Measure your rotors.
If you think you have cracks drag a fingernail across them, if your fingernail catches you have cause for concern, but if it's just a bit bumpy it's fine. These things are stout as fuck, 63k DD miles and 5x track days on my OE rotors. |
The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
09-29-2017, 12:44 PM | #14 |
Drives: Car
It's heat checking. It's normal from track use due to the high temps your stock rotors see. I would replace when one of the cracks reach the edge or is large enough to catch a fingernail. Another way to test is to check the minimum thickness of your rotors. I would carry spare rotors on you.
The Following 2 Users Say Thank You to FirstWinter For This Useful Post: | Icecreamtruk (10-02-2017), JoeC (09-29-2017) |
Similar Threads | ||||
DIY: Front Brake Pad and Brake Rotor Replacement | F1point4 | DIY (Do-It-Yourself) Guides | 28 | 03-21-2021 09:22 PM |
Brake rotor temperature right/left and front/rear comparison questions | HappyMonkey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 07-07-2017 02:29 PM |
Alcon Front Brake Kit, 4-piston 332x28mm Rotor Size - now available!! | FRSport.com | Brakes, Suspension, Chassis | 0 | 07-08-2016 07:14 PM |
Brake Pads + Rotor | Mikeez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-01-2015 09:34 AM |
