Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
01-02-2019, 10:58 PM | #1 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Replacement BRZ HID bulbs
When I hit a deer last year I had to have one of my headlights replaced. When my car came out of the shop I noticed my original HID (driver side) no longer matched my new HID (passenger side) so I bought a pair of CnLight 6000k bulbs, which looked awesome initially..perfect shade of white with a hint of blue. Lately I noticed they look borderline halogen when I am driving next to another car that has HID. They looked great for the past year but it looks like they have changed color; I did some research and found that the shift in color should go in the opposite direction. Has anyone else with these bulbs noticed this? I bought these from diodedynamics so I assume they are legit bulbs. I am ok with buying another set, can anyone recommend anything? Philips I assume is a safe bet?
01-03-2019, 08:06 AM | #2 |
Drives: WRB BRZ
Philips and Morimoto are both pretty good options and I believe Morimoto is slightly cheaper. The OEM bulbs are Osram Xenarc and can be purchased anywhere. The Retrofit Source has many different HID bulb brands to choose from with a couple different color temperatures for each. I believe 4300k is the color temperature of the OEM bulbs and has a slight orange/warm tinge. A higher number like 5000k would be mostly white and 6000k and above would start to have that blue/cool tinge.
01-03-2019, 05:59 PM | #3 |
Thanks, I am pretty familiar with HID in general. Yes, 4300k is the stock color temp and the higher you go the bluer/purple you get. The color temp is supposed to increase as they age..so 4300k can shift to 4800k over time, for example.
I am really just looking for an alternate brand recommendation for the 6000k color temp, that is not going to cost me $200. From what I read prior to purchasing, CnLight were supposed to be really good. Weird that they changed into 4300k-3000k color temp on me. At $60, you get what you pay for I guess. I guess I will maybe try Philips. I am out of the loop a bit on whats new, are we able to swap in LED bulbs into HID housings yet, while maintaining perfect beam pattern? |
01-03-2019, 10:12 PM | #4 |
ProCrastinationConsultant
no, hid is better then led. led can't currently get the same lumen output as hid. led's main advantage is lumens-per-watt, not overall lumens.
The Following User Says Thank You to soundman98 For This Useful Post: | B-R-Z (01-04-2019) |
01-05-2019, 11:39 AM | #5 |
Ended up going with Osram D4S CBB's which are rated at 'up to 7000k' but are actually more like 6000k.
I will post some comparison pics of the 1-year old CnLight 6000k's that DiodeDynamics sells versus the Osrams. |
Similar Threads | ||||
OLM 5000K Replacement HID Bulbs - NIB - $40 shipped | Koa | Exterior Parts (Aero, Lighting, Etc.) | 4 | 10-15-2017 09:55 PM |
WTB: Reverse white bulbs + clear switchback front turn signal bulbs | Xplicit | Canada Classifieds | 9 | 06-12-2016 11:47 AM |
FS: OEM side markers + bulbs. OEM turn signal bulbs. | akiranakayama | Exterior Parts (Aero, Lighting, Etc.) | 3 | 07-29-2015 12:25 PM |
LED bulbs | 86geek | Hawaii | 4 | 03-30-2015 03:12 AM |
H11 HID Bulbs | Jon11561 | NY / NJ / CT / PA | 5 | 02-02-2013 05:25 PM |
