Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-25-2014, 03:45 PM | #1 |
Drives: LS Swapped BRZ
Weird humming noise from behind radio in middle of dash
I search around and did not see anyone with this same problem, started about a 1.5 months ago, only happened 1 time at that point, happened to be right after vsc and traction control kicked in going though a wet puddle. I drove the last block to work, parked listened for the constant noise sounds like a blend door motor turning but never stopping... strange noise to say the least, I run a automotive shop that specializes in diagnostics and never have heard another car make this noise before. I turned the car off and the noise quit, turned the car back on and nothing, noise was gone.
Waiting a week or 2 and didn't hear the noise again until randomly happened again on my way home from work, at this point I figured something after the car is fully warmed up and driven at least 7 miles is causing this noise. again same issue car made the noise randomly and kept making the noise until I turned the vehicle off. its a very consistent medium level sound noise straight behind the radio/middle of the dash area. Over the last month now its been happening worse and worse, almost 3-4 times a week it happens, I stuck my head under the dash and really tried listening to the noise and I honestly have a hard time pin pointing where it is, can't find any forums that have someone with a similar noise issue. It honestly sounds like a blend door motor running constantly but it never changes or stops once it starts. and I turn radio off turn a/c off, change the mode door actuators to different settings and no change at all. Today it did it on my way to work and did something different, same sound but it wasn't just constant, it came, then stopped and came again a bunch of different times. Hopefully someone else has heard the same thing, because it's a little annoying and curious how far apart I need to go to fix it. |
12-01-2014, 02:43 PM | #2 |
Found the problem finally... It's the radio that's going bad. This morning radio start humming again like crazy and really starting cutting out the music and such... Wonder if they will replace the unit if I take it out and bring it to them.
10-17-2016, 04:45 PM | #3 |
Drives: 2013 Scion FR-S Firestorm MT
I'm getting the same strange noise, it sounds like a small fan running with a bad bearing. Does our head unites have an internal fan for cooling?
Parts List: Perrin CAI + Borla UEL Header + Perrin Overpipe + Invidia Front Pipe w/ High-Flow Catalytic Converter + FT-86 SpeedFactory V1 Exhaust + 10k HID's + Eibach Sportsline Springs + TRD Spoiler + Rear Diffuser + Rear Spats + OFT Stage 2 Tune +18" Enkei Black Raijin Wheels (18x8 +45 up front 18x9.5 +45 in rear) Tire Specs: 235/40R18 in the front, 265/35R18 in the rear
10-17-2016, 05:30 PM | #4 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
But seriously: yes, the stock touchscreen head unit has a fan on the side... |
The Following User Says Thank You to nextcar For This Useful Post: | metalmoses (10-17-2016) |
10-17-2016, 06:12 PM | #5 |
Thank you! That's disappointing, I guess I'll have to decide to either replace the head unit or come up with a fix for the noise. Regardless at least now I know where to start
10-17-2016, 06:40 PM | #6 |
Weight Weenie
Drives: 15 FR-S
The Following User Says Thank You to new2subaru For This Useful Post: | metalmoses (10-18-2016) |
10-17-2016, 06:50 PM | #7 |
Drives: 2015 BRZ Sport Tech CWP
Could be dust buildup in or around the fan. I would take the head unit out and apply some compressed air and see if that helps.
The Following 2 Users Say Thank You to Guru Woodman For This Useful Post: | metalmoses (10-18-2016), winsometang (10-26-2016) |
Similar Threads | ||||
Humming noise while driving | maylchi | Issues | Warranty | Recalls / TSB | 9 | 03-13-2015 01:29 AM |
help!! weird humming noise?? | sid94 | Issues | Warranty | Recalls / TSB | 3 | 05-17-2014 12:16 PM |
Weird Noise | FloridaBRZ | BRZ First-Gen (2012+) -- General Topics | 7 | 04-25-2014 08:35 PM |
Humming noise from the rear/gas tank? | Turbo95eg6 | Issues | Warranty | Recalls / TSB | 3 | 11-30-2013 04:10 PM |
Weird Dash Light | Pacific Auto | Issues | Warranty | Recalls / TSB | 4 | 10-31-2013 01:20 AM |
