03-29-2020, 04:41 PM | #3739 |
Drives: 86
Would you guys recommend the ALK, Pillowball, or stock bushing for a DD that gets tracked ~4 times a year? It seems like too much effort and wondering if the performance gains are worth in your opinion.
03-30-2020, 02:53 PM | #3740 | |
Like really really good. EDIT: it's not just "feel" though that is a big part of it. the OEM bushings do deflect during cornering and braking, and moreso with stickier tires. this results in dynamic alignment changes that do not help front grip. But...yes there is some additional harshness. And yes you have to be careful with salt/dirt if they're not protected. And they're not an inexpensive modification. So not the best choice for everyone. The Whiteline ALK works well too with only a small change in harshness. I would recommend an experienced installer. In general I don't prefer a poly type bushing in that location, but it does work and I haven't seen any problems. - Andrew Last edited by Racecomp Engineering; 03-30-2020 at 03:21 PM. |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | solidONE (03-30-2020) |
03-30-2020, 04:10 PM | #3741 |
Drives: 2014 GT86
I had whiteline alk. Poly part separated from metal after 2 years of DD & several trackdays. IIRC it failing is not that uncommon. Replaced it with non eccentric bushing by energy suspension. Got extra wished camber/caster via other means/at other joints.
The Following 2 Users Say Thank You to churchx For This Useful Post: | Racecomp Engineering (03-30-2020), solidONE (04-01-2020) |
04-01-2020, 02:37 AM | #3742 | |
Drives: FR-S Whiteout
Did they just slide out of the sleeve or did it tear? I can see it sliding outbbecause there is no flange to hold the urethane portion in place. Its only held in place with the adhesion of the liquid drying against the sleeve's wall. Not the smartest design for this location.. dang it.
Intent > Content
cowardice is the mother of cruelty. |
04-01-2020, 04:21 AM | #3743 |
Drives: 2014 GT86
You are free to install it, it probably won't fail for certain and immediately, but it's changes (slight extra caster and and stiffer less compliant joint) can be got in other ways. When it was time to change it, i decided to move it to my subjective list of not worth to buy 2nd replacement. Changes from it to handling didn't seem that worth it, not amounting to high noticeable impact or to something that i'd miss, or not reachable differently (eg. at topmount). But if you already have bought it, money already spent, you are free to install (at least if there are also other suspension goodies to install at same time and alignment will be redone anyway). Not something inherently bad or failing immediately.
The Following User Says Thank You to churchx For This Useful Post: | solidONE (04-01-2020) |
04-01-2020, 04:22 PM | #3744 |
I wanted the caster. I figured if was going to change out the bushings, who not? This is the first time I've read about this particular part failing, though I've heard of other whiteline brand parts failing. A slight change or an extra step to make sure the sleeve does not allow the urethane to separate there likely would not be this problem
It is what it is.. finger crossed, I guess.
Intent > Content
04-01-2020, 04:32 PM | #3745 |
How long have your OEM control arm bushings lasted?
- Andrew |
04-01-2020, 04:36 PM | #3746 |
I got 83K miles on them lol
Only did the diff carrier inserts about 3-4 months ago at 75K-ish. And my adjustable toe link has sphericals, but thats about it.
Intent > Content
04-01-2020, 05:13 PM | #3747 |
How long are they expected to last? How long did your's last?
Intent > Content
04-01-2020, 05:50 PM | #3748 |
Drives: 2014 GT86
@solidONE: increased caster pros are stronger steering centering & some dynamic camber gains (thus less static camber needed) when turning wheel. If it's on prerestyle, especially if on sticky tires, more caster may also make overwork electric power steering which was prone for some to overheat (supposedly fixed on MY2017). Also topmounts like raceseng cascam or pedders mounts IIRC also are able to net some caster. While there is certain need for tracked twin for extra static negative camber, especially front, not sure that extra caster is that much needed.
04-01-2020, 06:39 PM | #3749 |
Drives: Crapcan
I had issues with the energy bushing and went to the whiteline
04-01-2020, 06:50 PM | #3750 |
Drives: 2014 GT86
NoHaveMSG: well .. then if mine will fail, then i can always .. revert that bushing to stock. . But as it's non-eccentric and without those cutouts as on whiteline's, imho it should potentially last better.
04-01-2020, 09:15 PM | #3751 | |
I not.
Intent > Content
04-02-2020, 01:45 AM | #3752 |
Drives: 2014 GT86
@solidONE: i use bushing from powerflex, but the other one, rear one of front LCA, for extra camber, not caster. It allowed me together with two camberbolt sets to get -3 front with stock topmounts. IIRC for rear bushing other poly bushing wendors all have non-eccentric bushings for that joint, (if) eccentric ones (eg. whiteline alc, powerflex's one and so on) - only front one, for caster.
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
