Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-28-2017, 10:20 PM | #1 |
Works stage 2 install help
I'm trying to bolt the oil drain tube to the turbo and the exhaust flange is so close I can't get the bolt in the hole. Any suggestions?
05-28-2017, 10:44 PM | #2 |
Drives: Q5 + BRZ + M796
Does the bolt fit when the flange isnt there? If so then don't tighten the other bolt down before the difficult one is in place. Especially don't connect it at the top if you can.
05-28-2017, 10:55 PM | #3 |
Loosen the bolts on the turbo housing on both the intake and exhaust housings and rotate the center section to get the bolt in an easier location
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | drz400dude (05-29-2017) |
05-29-2017, 12:26 AM | #4 | |
Sent from my SAMSUNG-SM-N920A using Tapatalk |
05-29-2017, 12:37 AM | #5 | |
So you are either using the wrong bolts for those holes or the dimensions are off by the manufacturer. Your options are to reconsider how to make it fit or contact the manufacturer. You may need to post more pics for others to help see what is wrong. Or you can get a smaller bolt. Sent from my iPhone using Tapatalk
05-29-2017, 12:40 AM | #6 | |
On second look, have you tried rotating the turbo housing? Sent from my iPhone using Tapatalk
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | drz400dude (05-29-2017) |
05-29-2017, 12:49 AM | #7 | |
05-29-2017, 10:46 AM | #8 | |
05-29-2017, 08:23 PM | #10 |
Similar Threads | ||||
WORKS CARB Stage 2 Installed! Review | Mr_YUzU_FRS | Forced Induction | 94 | 05-26-2020 02:14 AM |
WORKS/Ohlins Stage II R&T Coilover Suspension | WORKS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 43 | 04-26-2018 08:12 PM |
Experience with Works Stage 1 Turbo Kit | aaguirre123 | Forced Induction | 33 | 09-18-2015 08:16 PM |
My Experience with Works Stage 1 Turbo Kit | aaguirre123 | Member's Car Journals | 9 | 06-09-2015 07:47 PM |
WORKS Stage 1 Turbo Kit Pre-Release Offer | WORKS | Northern California | 31 | 11-11-2014 07:24 PM |
